3.0.0-a5 Issues
3.0.0-a5 Issues
On startup of Windows Operating system if 3.0.0-a5 is set to launch on startup, the following error occurs:
Resolution so far is to terminate UMS, and relaunch.
ERROR 2013-09-03 21:40:01.362 [main] A serious error occurred during PMS init
java.lang.IllegalThreadStateException: process has not exited
at java.lang.ProcessImpl.exitValue(Unknown Source) ~[na:1.7.0_25]
at net.pms.PMS.checkProcessExistence(PMS.java:255) [ums.jar:3.0.0-a5]
at net.pms.PMS.init(PMS.java:590) [ums.jar:3.0.0-a5]
at net.pms.PMS.createInstance(PMS.java:1033) [ums.jar:3.0.0-a5]
at net.pms.PMS.main(PMS.java:1129) [ums.jar:3.0.0-a5]
- (12.35 KiB) Downloaded 967 times
Universal Media Server Wiki!
Re: 3.0.0-a5 Issues
Thanks, DeFlanko. Can you please try this version?
Re: 3.0.0-a5 Issues
I'm just now reading this... ill try when I get home.
Re: 3.0.0-a5 Issues
Befor i load up the custom version, Subjunk, i found an interesting loop when trying to stream to my Asus TF300T:
Changed debug level to TRACE
09-05 19:15:09 Started playing The Avengers.2012.mp4 on your Asus Transformer TF300T
09-05 19:15:16 Buffer read ArrayIndexOutOfBoundsException error:
09-05 19:15:16 readCount: "4294680576"
09-05 19:15:16 maxMemorySize: "209715200"
09-05 19:15:24 Buffer read ArrayIndexOutOfBoundsException error:
09-05 19:15:24 readCount: "4294680576"
09-05 19:15:24 maxMemorySize: "209715200"
09-05 19:15:27 Starting transcode/remux of The Avengers.2012.mp4
09-05 19:15:28 Stopped playing The Avengers.2012.mp4 on your Asus Transformer TF300T
09-05 19:15:33 Started playing The Avengers.2012.mp4 on your Asus Transformer TF300T
09-05 19:15:41 Buffer read ArrayIndexOutOfBoundsException error:
09-05 19:15:41 readCount: "4294680576"
09-05 19:15:41 maxMemorySize: "209715200"
09-05 19:15:48 Buffer read ArrayIndexOutOfBoundsException error:
09-05 19:15:48 readCount: "4294680576"
09-05 19:15:48 maxMemorySize: "209715200"
09-05 19:15:51 Starting transcode/remux of The Avengers.2012.mp4
09-05 19:15:52 Stopped playing The Avengers.2012.mp4 on your Asus Transformer TF300T
09-05 19:15:58 Started playing The Avengers.2012.mp4 on your Asus Transformer TF300T
- (109.54 KiB) Downloaded 968 times
Re: 3.0.0-a5 Issues
a6, showed the same loop.
will try and reproduce the original, at windows boot up issue, shortly.
Re: 3.0.0-a5 Issues
Yeah I get pretty confused by that part of the code to be honest. It has been buggy for years and the way it was written has very few comments and the variable names aren't descriptive so...
Re: 3.0.0-a5 Issues
No worries then.. issue closed.
Its an inherited problem. Its ok...
