UMS 3.0.0-a5
crack00r
UMS 3.0.0-a5
Post by crack00r »
Hi, i have a Problem with UMS 3.0.0-a5
On 1st install and start it runs ok
but after reboot, i just get this error in log
Anyone know some help?
2.6.5 runs ok
09-13 09:44:28  Found plugin: com.sharkhunter.channel.CH_plugin
09-13 09:44:28  Exception in thread "main" java.lang.VerifyError: class com.chocolatey.pmsencoder.PMSEncoder overrides final method launchTranscode.(Ljava/lang/String;Lnet/pms/dlna/DLNAResource;Lnet/pms/dlna/DLNAMediaInfo;Lnet/pms/io/OutputParams;)Lnet/pms/io/ProcessWrapper;
09-13 09:44:28  	at java.lang.ClassLoader.defineClass1(Native Method)
09-13 09:44:28  	at java.lang.ClassLoader.defineClass(Unknown Source)
09-13 09:44:28  	at java.security.SecureClassLoader.defineClass(Unknown Source)
09-13 09:44:28  	at java.net.URLClassLoader.defineClass(Unknown Source)
09-13 09:44:28  	at java.net.URLClassLoader.access$100(Unknown Source)
09-13 09:44:28  	at java.net.URLClassLoader$1.run(Unknown Source)
09-13 09:44:28  	at java.security.AccessController.doPrivileged(Native Method)
09-13 09:44:28  	at java.net.URLClassLoader.findClass(Unknown Source)
09-13 09:44:28  	at java.lang.ClassLoader.loadClass(Unknown Source)
09-13 09:44:28  	at java.lang.Class.getDeclaredConstructors0(Native Method)
09-13 09:44:28  	at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
09-13 09:44:28  	at java.lang.Class.getConstructor0(Unknown Source)
09-13 09:44:28  	at java.lang.Class.newInstance0(Unknown Source)
09-13 09:44:28  	at java.lang.Class.newInstance(Unknown Source)
09-13 09:44:28  	at net.pms.external.ExternalFactory.instantiateEarlyListeners(ExternalFactory.java:419)
09-13 09:44:28  	at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:399)
09-13 09:44:28  	at net.pms.PMS.init(PMS.java:658)
09-13 09:44:28  	at net.pms.PMS.createInstance(PMS.java:1033)
09-13 09:44:28  	at net.pms.PMS.main(PMS.java:1129)
(12.85 KiB) Downloaded 719 times
orgon3
Re: UMS 3.0.0-a5
Post by orgon3 »
I get a separate issue, but similar enough to post in the same thread I guess. Attached is my debug log. Latest Java 7u40 64bit (is being used by default by the program, finally :P). Pretty default install options (Clean Install of course) and just set it up for my network.
(22.32 KiB) Downloaded 714 times
DeFlanko
Contact:
Re: UMS 3.0.0-a5
Post by DeFlanko »
These are plugin errors that are not yet compatible with 3.0.0-a5
...also noticed you have a SCH-I545...ill add that to the list.. =)
orgon3
Re: UMS 3.0.0-a5
Post by orgon3 »
DeFlanko wrote:These are plugin errors that are not yet compatible with 3.0.0-a5
Whoops. There I go, jumping to conclusions on my Jump To Conclusions mat. Sorry for the trouble. And yes, my roommate does have an S4, and would actually use it to stream, lol. Thanks a lot for everything!
(also, would you know any reason why only tsmuxer shows up on the Sharp Aquos? I am just confused as to why it wouldn't accept a transcoded stream. It shouldn't know the difference..........)
DeFlanko
Contact:
Re: UMS 3.0.0-a5
Post by DeFlanko »
no idea lol
Wolfgan
Re: UMS 3.0.0-a5
Post by Wolfgan »
In relation to the wrong container detected (see viewtopic.php?f=3&t=1147&start=20#p7140), I found some clue on going thru the logs. It seems ffmpeg detects various containers on the streams:
DEBUG 2013-09-24 17:02:40.280 [Thread-32] Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\zInetTransfer\!(0TV) Various\Bones.S09E02.HDTV.x264-LOL.mp4':
DEBUG 2013-09-24 17:02:40.280 [Thread-32]   Metadata:
DEBUG 2013-09-24 17:02:40.280 [Thread-32]     major_brand     : isom
DEBUG 2013-09-24 17:02:40.280 [Thread-32]     minor_version   : 1
DEBUG 2013-09-24 17:02:40.280 [Thread-32]     compatible_brands: isom
Full logs attached for further review. Thanks! Wolf
Debug logs
(15.92 KiB) Downloaded 695 times
