UE55KS8002 cant play 4k video
dennisreyes
4K
Post by dennisreyes »
Does the Universal Media Server play back 4K movies. :D
Sami32
Re: 4K
Post by Sami32 »
Yes.
Though very few renderers have this settings set by default, as it need lot of CPU power and network bandwidth, to avoid users "stuttering" issues appear.
Adding these 2 lines in your renderer configuration file will give 4K streaming possibility:
MaxVideoWidth = 3840
MaxVideoHeight = 2160
kocka68785602
Post by kocka68785602 »
hello
i have a UE55KS8002 samsung tv but cant play any 4k content, i changed the maximum bit rate to 0 but no luck
(1014.41 KiB) Downloaded 780 times
kocka68785602
Re: 4K
its not working for me
samsung UE55KS8002
(913.58 KiB) Downloaded 1023 times
Re: UE55KS8002 cant play 4k video
It looks like we need to add a renderer config for your TV, can you find a manual for it online so we can see what files it supports?
kocka68785602
so my issue is that i can play the file from an external drive but i can make anything in 4k work whit UMS.
i found this for the file types
https://www.samsung.com/us/support/answer/ANS00049952/
I made a new renderer config for your TV based on the manual, can you please test it using this installation? I built it on top of 7.0.0-rc2: http://www.spirton.com/uploads/UMS/UMS- ... 785602.exe
kocka68785602
thanks for your hard work!
We have progress
New error :)
it plays the files new and not killing my cpu in the process but as i load the file it starts to play for 1-2 se and loads it from the start but there is a 5 sec audio delay and i can seek in the video
new build ums_dbg.zip
(1.77 MiB) Downloaded 932 times
Thanks for testing, here's a new one http://www.spirton.com/uploads/UMS/UMS- ... 5602-2.exe
kocka68785602
thanks for the quick fix all is god exept some HDR files are not transfering as HDR :D
new build ums_dbg -2.zip
(1.22 MiB) Downloaded 830 times
