Version 7.0.0-rc2 released
General:
The 7.0.0 version adds new features to dynamically sort your media, most notably there are new "TV Shows" and "Movies" folders that are populated automatically with content from your shared folders.
Your feedback on this release candidate will be valuable, so let us know how it is working for you!
Note: This is a release candidate, which means the feature list is complete and it should be stable. It is likely to be the last non-final release of 7.0.0.
Note: It is recommended you take a backup of your profile directory before installing this, as the DATABASE CHANGES ARE NOT REVERSIBLE. The location of your profile directory are near the top of the "Logs" tab in the program.
Download:
Windows
Linux
macOS
Changes since 7.0.0-rc1:
  • General:
    • Added "Watched" folders to the Media Library, to mirror "Unwatched" functionality
    • Fixed crashing when shared folders don't exist, aren't folders, or access is denied
    • Fixed broken Media Library entries
    • New Media folder is hidden by default (the same functionality exists in Media Library)
    • All changes in 6.7.3, 6.7.4 and 6.8.0
  • Dependencies:
    • Updated h2database to 1.4.196
erick diangilis
Re: Version 7.0.0-rc2 released
Post by erick diangilis »
hi subjunk ive tested this release its working fine on the regular ps4 but i didn't like the way my laptop behave like it did with the 6.7.8 it worked much less stable and i could hear the cooler over accelerating and the memory usage on the ums bar during a playback was too unstable as well i compared with the other one my laptop behaved much more silenced using less memory for the same vídeos. for safety reasons i found much more seccure to stay with the 6.7.8 and keep it until 7 is working the same way.
thanks again for both releases and i hope this report help in someway. happy new year. ;)
Bubblebond
Post by Bubblebond »
This new version work well with the PS4 pro with 4K , but only Cpu is used , the GPU is not used, even if the option is activated. I have tried with several files .
bodom
Post by bodom »
I've been using it for a couple of months now.
It does not seem to have any big issue, except that it needs to be restarted every 2-3 days because it goes "crazy" and starts eating all the CPU, making the whole system very slow.
It would be great if you could attach logs after it starts going crazy so we can see why
bodom
Post by bodom »
Just an update: since I wrote my last post, I had no more freezes.
bodom
Post by bodom »
Ok, it happened again today on version 7.0.0 (no RC). I am posting it here to follow up on same thread.
CPU is stuck at 100%, UMS is barely responsive.
On the console i have
INFO  23:33:06.505 [cling-3350] Exception in thread "cling-3350" java.lang.NullP
ointerException
INFO  23:33:06.505 [cling-3350]         at net.pms.configuration.DeviceConfigura
tion.crossReference(DeviceConfiguration.java:231)
INFO  23:33:06.505 [cling-3350]         at net.pms.configuration.DeviceConfiguration.getDeviceUpnpMode(DeviceConfiguration.java:224)
INFO  23:33:06.506 [cling-3350]         at net.pms.network.UPNPHelper.isBlocked(UPNPHelper.java:644)
INFO  23:33:06.506 [cling-3350]         at net.pms.network.UPNPControl$2.remoteDeviceAdded(UPNPControl.java:307)
INFO  23:33:06.506 [cling-3350]         at org.fourthline.cling.registry.RemoteItems$1.run(RemoteItems.java:111)
INFO  23:33:06.506 [cling-3350]         at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
INFO  23:33:06.506 [cling-3350]         at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
INFO  23:33:06.506 [cling-3350]         at java.lang.Thread.run(Thread.java:748)
In the debug.log
DEBUG 2018-04-20 23:32:28.308 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2018-04-20 23:32:59.910 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2018-04-20 23:33:04.417 [HTTPv2 Request Worker 8] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:04.657 [HTTPv2 Request Worker 1] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:04.657 [HTTPv2 Request Worker 2] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:05.897 [cling-4014] Matched media renderer "Samsung E+ Series" based on dlna details "[TV] Samsung Q7 Series (65) --IP-- uuid:--uuid-- Samsung Electronics QE65Q7FAM AllShare1.0 Samsung TV DMR http://www.samsung.com/sec http://www.samsung.com/sec"
DEBUG 2018-04-20 23:33:05.897 [cling-4014] Updating status button for [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.925 [cling-4014] Found upnp service for "[TV] Samsung Q7 Series (65)" with dlna details: {friendlyName=[TV] Samsung Q7 Series (65), address=--IP--, udn=uuid:--uuid--, manufacturer=Samsung Electronics, modelName=QE65Q7FAM, modelNumber=AllShare1.0, modelDescription=Samsung TV DMR, manufacturerURL=http://www.samsung.com/sec, modelURL=http://www.samsung.com/sec}
DEBUG 2018-04-20 23:33:05.925 [cling-4014] Adding device: urn:schemas-upnp-org:device:MediaRenderer:1 (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:--uuid--, Descriptor: http://--IP--:9197/dmr, Root: true
DEBUG 2018-04-20 23:33:05.925 [cling-4014] Subscribing to RenderingControl service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.925 [cling-4014] Subscribing to ConnectionManager service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.925 [cling-4014] Subscribing to AVTransport service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.925 [cling-4014] Subscribing to StreamSplicing service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.935 [cling-4003] Subscription established: AVTransport on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.938 [cling-4003] Subscription established: ConnectionManager on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.940 [cling-4003] Subscription established: RenderingControl on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:05.949 [cling-4003] Subscription established: StreamSplicing on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:06.489 [HTTPv2 Request Worker 3] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:06.814 [cling-4012] AVTransportURI:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] AVTransportURIMetaData:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentMediaDuration: 0:00:00
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentPlayMode: NORMAL
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentRecordQualityMode: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentTrack: 0
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentTrackDuration: 0:00:00
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentTrackMetaData:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentTrackURI:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] CurrentTransportActions:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] NextAVTransportURI:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] NextAVTransportURIMetaData:
DEBUG 2018-04-20 23:33:06.814 [cling-4012] NumberOfTracks: 0
DEBUG 2018-04-20 23:33:06.814 [cling-4012] PlaybackStorageMedium: NETWORK,NONE
DEBUG 2018-04-20 23:33:06.814 [cling-4012] PossiblePlaybackStorageMedia: NETWORK,NONE
DEBUG 2018-04-20 23:33:06.814 [cling-4012] PossibleRecordQualityModes: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:06.814 [cling-4012] PossibleRecordStorageMedia: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:06.814 [cling-4012] RecordMediumWriteStatus: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:06.814 [cling-4012] RecordStorageMedium: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:06.814 [cling-4012] TransportPlaySpeed: 1
DEBUG 2018-04-20 23:33:06.814 [cling-4012] TransportState: NO_MEDIA_PRESENT
DEBUG 2018-04-20 23:33:06.814 [cling-4012] TransportStatus: OK
DEBUG 2018-04-20 23:33:06.815 [cling-4012] Mute: 1
DEBUG 2018-04-20 23:33:06.815 [cling-4012] PresetNameList: FactoryDefaults
DEBUG 2018-04-20 23:33:06.815 [cling-4012] Volume: 5
DEBUG 2018-04-20 23:33:06.815 [cling-4012] X_360View:
DEBUG 2018-04-20 23:33:06.815 [cling-4012] X_AspectRatio: Default
DEBUG 2018-04-20 23:33:06.815 [cling-4012] X_Captions:
DEBUG 2018-04-20 23:33:06.815 [cling-4012] X_EnabledCaptions:
DEBUG 2018-04-20 23:33:06.815 [cling-4012] X_ServiceCapabilities: GetVolume,SetVolume,GetMute,SetMute
DEBUG 2018-04-20 23:33:07.153 [cling-4013] Subscription cancelled: RenderingControl on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:07.153 [cling-4014] Subscription cancelled: AVTransport on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:07.153 [cling-3998] Subscription cancelled: StreamSplicing on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:07.153 [cling-4012] Subscription cancelled: ConnectionManager on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:07.153 [cling-3994] [TV] Samsung Q7 Series (65) is now offline.
ERROR 2018-04-20 23:33:07.820 [UPNP-[TV] Samsung Q7 Series (65)] Failed to send action "GetPositionInfo" to [TV] Samsung Q7 Series (65): Error: Current state of service prevents invoking that action. Connection error or no response received.
DEBUG 2018-04-20 23:33:27.866 [HTTPv2 Request Worker 4] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:28.104 [HTTPv2 Request Worker 6] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:28.104 [HTTPv2 Request Worker 5] Recognized media renderer "[TV] Samsung Q7 Series (65)"
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Matched media renderer "Samsung E+ Series" based on dlna details "[TV] Samsung Q7 Series (65) --IP-- uuid:--uuid-- Samsung Electronics QE65Q7FAM AllShare1.0 Samsung TV DMR http://www.samsung.com/sec http://www.samsung.com/sec"
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Updating status button for [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Found upnp service for "[TV] Samsung Q7 Series (65)" with dlna details: {friendlyName=[TV] Samsung Q7 Series (65), address=--IP--, udn=uuid:--uuid--, manufacturer=Samsung Electronics, modelName=QE65Q7FAM, modelNumber=AllShare1.0, modelDescription=Samsung TV DMR, manufacturerURL=http://www.samsung.com/sec, modelURL=http://www.samsung.com/sec}
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Adding device: urn:schemas-upnp-org:device:MediaRenderer:1 (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:--uuid--, Descriptor: http://--IP--:9197/dmr, Root: true
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Subscribing to RenderingControl service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Subscribing to ConnectionManager service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Subscribing to AVTransport service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.262 [cling-4012] Subscribing to StreamSplicing service on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.274 [cling-4018] Subscription established: ConnectionManager on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.274 [cling-4018] Subscription established: RenderingControl on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.477 [cling-4018] Subscription established: StreamSplicing on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:29.478 [cling-4018] Subscription established: AVTransport on [TV] Samsung Q7 Series (65)
DEBUG 2018-04-20 23:33:30.202 [cling-4017] AVTransportURI:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] AVTransportURIMetaData:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentMediaDuration: 0:00:00
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentPlayMode: NORMAL
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentRecordQualityMode: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentTrack: 0
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentTrackDuration: 0:00:00
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentTrackMetaData:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentTrackURI:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] CurrentTransportActions:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] NextAVTransportURI:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] NextAVTransportURIMetaData:
DEBUG 2018-04-20 23:33:30.202 [cling-4017] NumberOfTracks: 0
DEBUG 2018-04-20 23:33:30.202 [cling-4017] PlaybackStorageMedium: NETWORK,NONE
DEBUG 2018-04-20 23:33:30.202 [cling-4017] PossiblePlaybackStorageMedia: NETWORK,NONE
DEBUG 2018-04-20 23:33:30.202 [cling-4017] PossibleRecordQualityModes: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:30.202 [cling-4017] PossibleRecordStorageMedia: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:30.202 [cling-4017] RecordMediumWriteStatus: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:30.202 [cling-4017] RecordStorageMedium: NOT_IMPLEMENTED
DEBUG 2018-04-20 23:33:30.202 [cling-4017] TransportPlaySpeed: 1
DEBUG 2018-04-20 23:33:30.202 [cling-4017] TransportState: NO_MEDIA_PRESENT
DEBUG 2018-04-20 23:33:30.202 [cling-4017] TransportStatus: OK
DEBUG 2018-04-20 23:33:30.203 [cling-4010] Mute: 1
DEBUG 2018-04-20 23:33:30.203 [cling-4010] PresetNameList: FactoryDefaults
DEBUG 2018-04-20 23:33:30.203 [cling-4010] Volume: 5
DEBUG 2018-04-20 23:33:30.203 [cling-4010] X_360View:
DEBUG 2018-04-20 23:33:30.203 [cling-4010] X_AspectRatio: Default
DEBUG 2018-04-20 23:33:30.203 [cling-4010] X_Captions:
DEBUG 2018-04-20 23:33:30.203 [cling-4010] X_EnabledCaptions:
DEBUG 2018-04-20 23:33:30.203 [cling-4010] X_ServiceCapabilities: GetVolume,SetVolume,GetMute,SetMute
DEBUG 2018-04-20 23:33:31.640 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2018-04-20 23:33:33.258 [cling-4017] Subscription cancelled: AVTransport on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:33.258 [cling-4003] Subscription cancelled: RenderingControl on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:33.258 [cling-3996] [TV] Samsung Q7 Series (65) is now offline.
DEBUG 2018-04-20 23:33:33.258 [cling-4010] Subscription cancelled: ConnectionManager on uuid:--uuid--: DEVICE_WAS_REMOVED
DEBUG 2018-04-20 23:33:33.258 [cling-4008] Subscription cancelled: StreamSplicing on uuid:--uuid--: DEVICE_WAS_REMOVED
ERROR 2018-04-20 23:33:34.220 [UPNP-[TV] Samsung Q7 Series (65)] Failed to send action "GetPositionInfo" to [TV] Samsung Q7 Series (65): Error: Current state of service prevents invoking that action. Connection error or no response received.
DEBUG 2018-04-20 23:34:03.247 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2018-04-20 23:34:34.987 [UPNP-AliveMessageSender] Sending ALIVE...
I am now installing 7.0.1 and restarting it.
Should be fixed in 7.0.1
