Version 1.0.1 is released
Existing Windows users can download it automatically on the General Configuration tab in UMS.
Changes since 1.0:
  • Fixed a bug where XBOX 360 couldn't see the server (thanks to cmonster and Secate for testing)
  • Lots of language updates and fixes
  • AviSynth support was broken for some languages
  • Fixed an iPhoto bug
  • More branding
  • Code improvements
cmonster
Re: Version 1.0.1 is released
Post by cmonster »
We have a winner, it works! Me and my XBox are happy and we thank you.
DubbelX
Post by DubbelX »
Thanks, I'm switch over.
Madoka
Post by Madoka »
Not a real problem, more just asthetics, the auto update download window says "PMS Media Server Auto Update".
Madoka wrote:Not a real problem, more just asthetics, the auto update download window says "PMS Media Server Auto Update".
Thanks for reporting it, it's one of the fixes in this version :)
DubbelX
Post by DubbelX »
CardcaptorRLH85
Post by CardcaptorRLH85 »
The only issue I see with the 1.0.1 release is, much like Madoka's issue, a cosmetic one. On my Xbox360 this program still shows up as "PS3 Media Server [<Computer-Name>]". The program still streams just fine, once I finished changing the settings to match my old PMS ones, but that was to be expected. Nice job here ^_^
CardcaptorRLH85 wrote:The only issue I see with the 1.0.1 release is, much like Madoka's issue, a cosmetic one. On my Xbox360 this program still shows up as "PS3 Media Server [<Computer-Name>]". The program still streams just fine, once I finished changing the settings to match my old PMS ones, but that was to be expected. Nice job here ^_^
Thanks for reporting that, I'll look into it for the next release :)
CardcaptorRLH85
Hmm...I don't know what happened but, after restarting both the server and my 360, it says Universal Media Server now. Do both programs use the same port? I think the problem may have been the fact that I had both programs running at the same time while setting up UMS' settings before exiting PMS and testing UMS' streaming.
Yeah, they do use the same port by default :)
