Samsung 2-4k playback issues
Hi Guys,
i'm hoping you can help me somehow!
i'm using a samsung UE40MU6120 with desktop UMS. for some reason when i try to play 2 or 4k movies, i get a few issues.
- either the file doesn't play at all, stating "check internet connection" but after a few attempts starts to work
- file works but constantly buffers every 5 seconds
- always unable to forward/rewind
and occasionally, the file plays with no problems at all.
is there any way to resolve this?
thanks so much.
thanks so much.
- (39.64 KiB) Downloaded 613 times
Re: Samsung 2-4k playback issues
I have the same TV. Go into your UMS install folder and find the file Samsung-NotCD.conf inside the renderers folder. Open it in a text editor, clear everything, and paste the following:
Then save the file, quit UMS and restart it. Then try to play the video and it'll probably work. With these settings it probably won't have to transcode the 4K movies, which will take all of the mentioned problems away. See also my thread here.
# Profile for Samsung E+ series TVs and Blu-ray players with AllShare DLNA.
# http://ps3mediaserver.org/forum/viewtopic.php?f=15&t=8889
# Version: 1.4.4 (modified)
RendererName = Samsung E+ Series
# TV: User-Agent:
# UE46ES8000 SEC_HHP_[TV]UE46ES8000/1.0 DLNADOC/1.50
# UE40H 5500AW SEC_HHP_[TV]Samsung LED40/1.0 DLNADOC/1.50
# SEC_HHP_[TV] Samsung/1.0 DLNADOC/1.50
# UN55ES6100 SEC_HHP_[TV]UN55ES6100/1.0 DLNADOC/1.50
# UE37ES5500 SEC_HHP_[TV]UE37ES5500/1.0 DLNADOC/1.50
# Note: for maximum compatibility the regex is defined negatively as anything
# not matching a C/D series UA (see SamsungAllShare-CD.conf). The positive
# definition would be:
# UserAgentSearch = SEC_HHP.*(TV|HT|BD).*([E-Z]S?\d{4}|Samsung.*\d{2})/
UserAgentSearch = SEC_HHP(?!.*[CD]S?\d{3}\d?/)
UpnpDetailsSearch = (?!.*[CD]S?\d{3}\d?) , (Samsung|AllShare)
DefaultVBVBufSize = true
MuxDTSToMpeg = true
MaxVideoBitrateMbps = 80
TranscodedVideoFileSize = 1000000
ChunkedTransfer = true
SubtitleHttpHeader = CaptionInfo.sec
PrependTrackNumbers = true
CharMap = / :
MediaInfo = true
# Supported video formats:
Supported = f:avi|mkv m:video/avi
Supported = f:flv m:video/mp4
Supported = f:mov m:video/quicktime
Supported = f:mp4|mpegps|mpegts m:video/mpeg
# Supported audio formats:
Supported = f:mp3 m:audio/mpeg
Supported = f:wav m:audio/L16
SupportedExternalSubtitlesFormats = SUBRIP,ASS,TEXT,MICRODVD,WEBVTT,SAMI
SupportedInternalSubtitlesFormats = SUBRIP,ASS,TEXT,MICRODVD,WEBVTT,SAMI
SeekByTime = exclusive
MaxVideoWidth = 3840
MaxVideoHeight = 2160
SupportedVideoBitDepths = 8,10
H264Level41Limited = false
StreamSubsForTranscodedVideo = false
@abcd If/when you have a renderer configuration that works really well for your renderer, you should create a pull request here: https://github.com/UniversalMediaServer ... rver/pulls
with the new configuration file. That way your work figuring it out can be shared with others by default as it will be distributed with UMS.
That's a good idea, I'll try that when I have tried your branch build to see how the subs work. I'll need to figure out my TV's user agent though, does UMS show or log that somewhere? Also, I personally changed TranscodeVideo to MPEGTS-H264-AC3. The TV also works with H265, but my PC can't actually handle transcoding to that (maybe I just put UMS's quality settings too high?). What do you suggest I use for TranscodeVideo?Nadahar wrote: ↑Sat Jan 27, 2018 2:33 am @abcd If/when you have a renderer configuration that works really well for your renderer, you should create a pull request here: https://github.com/UniversalMediaServer ... rver/pulls
If you turn on "trace" logging the user agent should be logged when the device connects.
Regarding transcoding I would go with h264 for now. h265 is still a bit to immature and is generally quite heavy without hardware acceleration. The bandwidth saved by using h265 over your local network probably isn't noticeable, so h264 should be a safe bet.
abcd, thank you so for this.
i'm getting another issue now though.. every 10 or so seconds, the screen is going fuzzy and distorted :S.
First thing to check is if the video is still being transcoded or not. To check this, go to the video on your TV and check the filesize of the video (bottom left corner while in the file browser). If the size is something just under 1000 kB, the file is being transcoded. If the size is a lot larger (depends on video length and quality, but it's probably at least a few hundreds of MBs), it's not being transcoded.
Hi @backs999,
You have set the TRACE mode only after having started the logging, so we miss some useful informations.
Whatever, don't expect to get HEVC 4K 10-bit being smootly transcoded to MPEG-2 with your CPU
No way.
We miss the CPU info so i cannot even say if your CPU will support transcoding such media to H.264, but except if you've the latest Intel processor i don't think so.
You need to get or create an approppriate renderer that fit your need.
I did made one some months ago for an other user, so if you want try:
http://sendanywhe.re/8864ONUO
It was done for an other fork, so i slightly adapted it for your need.
No way.
hey Sami,
thanks alot.
i have a i5 6600k, is that really not sufficient?
thanks alot.
Sami32, did you actually read the entire thread? Because I don't think the backs999's video is still being transcoded with the conf file I sent. Also, I took a quick look at the conf file you sent and you have SeekByTime set to true, which just doesn't work for the UE40MU6120. (It needs to be set to exclusive.)
