MKV audio cuts out after 5 or 10 minutes
cbsewell
Post by cbsewell »
Wasn't sure where to post this as it happens with both the stable UMS release and the a5 release I am now running. The logs are from the A5 release.
I have several DVD's I 've ripped to MKV format with MakeMKV. When playing one of these DVD ripped MKV's on my PS3 using the standard method, which I guess uses MENCODER, the audio is completely out of sync from from the video. If I play back using transcoding and select tsMuxer, the audio and video is completely in sync, and it plays fine for 5 or 10 minutes, and then the audio cuts out. If I stop, wait a second or two, and then play it again, it resumes from where I stopped it, and the audio is once again OK. After another 5 or 10 minutes, the audio cuts out again. It goes on like this for the entire movie.
What could be the problem? TRACE log file attached.
(49.65 KiB) Downloaded 510 times
cbsewell
Re: MKV audio cuts out after 5 or 10 minutes
Post by cbsewell »
If I remux the videos to M2TS with PS3 Muxer, they play fine.
