[Resolved] Playstation 4 no longer detects UMS
paup
Post by paup »
I sat up a UMS server on my computer to stream video to my PlayStation 4 via WiFi some months back. As far as I remember this was a case of installing UMS on my computer and it immediately worked without any hassle.
For some reason it suddenly stopped working. I can now no longer enter the media player on the Playstation because it doesn't detect any media servers.
On the computer I can't see the PS4 as a renderer, but I do see my TV.
I did update Java recently and the problems might have started after that. I'm not entirely sure when the PS4 last updated, but I don't think that happened recently. After this problem starting to occur I upgraded UMS to a more recent version (from 6.7.4 to 7.0.0-rc2), but to no avail.
As per guidelines I added a trace log.
Any solutions?
(45.83 KiB) Downloaded 1188 times
Rejpal
Re: Playstation 4 no longer detects UMS
Post by Rejpal »
Most definitilely is your new version of JAVA blocked on Windows firewall - open firewall settings and add the latest version of javaw.exe as open for all apps and all incoming/outgoing connections
paup
Post by paup »
Thanks, indeed that was the case! Enabling Java private network access in Window Defender Firewall settings resolved the issue.
Re: [Resolved] Playstation 4 no longer detects UMS
Not true. It works fine if set up properly.
