Sony KDL-48R550C
Chiron69
Sony KDL-48R550C
Post by Chiron69 »
Greetings from France. :)
I own a Sony KDL-48R550C, but it's not recognized.
I tried to follow the guide http://www.universalmediaserver.com/faq ... erSupport1
I've taken an existing renderer and created then a file named Sony-KDL48R550C.conf and tried to update it.
# Profile for Sony Bravia X series TVs.
RendererName = Sony Bravia X
# friendlyName=KDL-48R550C, modelName=KDL-48R550C
# Versions of this renderer include:
# FW-??X7001D, KD-??S8000D, KD-??X7000D, KD-??X7500D, KD-??X8000D, KD-??X8300D, KD-??Z9D
# (?: 0-9)
UserAgentAdditionalHeader =
UserAgentAdditionalHeaderSearch =
UpnpDetailsSearch = Sony , (KD|FW)-[0-9][0-9](S|X|Z)[0-9]{1,4}D
MediaInfo = true
# Supported video formats:
Supported = f:3gp|3g2   v:h264|mp4           a:aac-lc|he-aac|ac3|eac3|mpa              m:video/3gpp
Supported = f:avi       v:mp4|mjpeg          a:ac3|eac3|mp3|mpa                        m:video/avi
Supported = f:mkv       v:mp4|h264|vp8       a:aac-lc|he-aac|ac3|dts|eac3|mpa|vorbis   m:video/x-matroska
Supported = f:mkv       v:h265               a:aac-lc|he-aac|ac3|dts|eac3              m:video/x-matroska
Supported = f:mov       v:mp4|h264|mjpeg     a:aac-lc|he-aac|ac3|eac3|mpa|lpcm         m:video/quicktime
Supported = f:mp4       v:h264               a:aac-lc|he-aac|ac3|eac3|mpa              m:video/mp4
Supported = f:mp4       v:h265               a:aac-lc|he-aac|ac3|eac3                  m:video/mp4
Supported = f:mpegps    v:mpeg1|mpeg2        a:ac3|lpcm|mpa                            m:video/mpeg
Supported = f:mpegts    v:h264|mpeg1|mpeg2   a:aac-lc|he-aac|ac3|eac3|mpa              m:video/mpeg
Supported = f:webm      v:vp8                a:vorbis                                  m:video/webm
Supported = f:wmv       v:wmv|vc1            a:wma                                     m:video/x-ms-wmv
# Supported audio formats:
Supported = f:m4a   m:audio/x-m4a
Supported = f:flac   m:audio/flac
Supported = f:mp3   m:audio/mpeg
Supported = f:wav   m:audio/wav
Supported = f:wma   m:audio/x-ms-wma
The problem is that there are no parameter to change as instructed in the wiki, such as:
UserAgentSearch =
Shall I add it?
The debug file returns:
DEBUG 2018-03-21 11:03:48.041 [cling-5] Updating status button for KDL-48R550C
DEBUG 2018-03-21 11:03:48.041 [cling-5] Found upnp service for "KDL-48R550C" with dlna details: {friendlyName=KDL-48R550C, address=192.168.26.227, udn=uuid:13a89cd6-1e0f-11b2-89dd-ac9b0a65533a, manufacturer=ACCESS CO., LTD., modelName=NFLC SDK v1.5, modelNumber=1.0, modelDescription=IPI Media Renderer, manufacturerURL=http://www.access-company.com/, modelURL=http://www.access-company.com/}
DEBUG 2018-03-21 11:03:48.041 [cling-5] Adding device: urn:schemas-upnp-org:device:MediaRenderer:1 (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:13a89cd6-1e0f-11b2-89dd-ac9b0a65533a, Descriptor: http://192.168.26.227:2870/dmr.xml, Root: true
DEBUG 2018-03-21 11:03:48.041 [cling-5] Subscribing to RenderingControl service on KDL-48R550C
DEBUG 2018-03-21 11:03:48.041 [cling-5] Subscribing to ConnectionManager service on KDL-48R550C
DEBUG 2018-03-21 11:03:48.042 [cling-5] Subscribing to AVTransport service on KDL-48R550C
but nothing with "Received on socket"
Can somebody give me a hand, please?
valib
Re: Sony KDL-48R550C
Post by valib »
You can simply change the
to
UpnpDetailsSearch = KDL-48R550C
or
UpnpDetailsSearch = KDL-[0-9][0-9]R[0-9][0-9][0-9]C
Chiron69
Post by Chiron69 »
Thank you very much.
I have changed the file and tried to run again.
The TV connects to the server but the navigation is very very slow, it's almost unusable. I've been able to read a video, but it's hard to tell more at the moment
Attached:
- my actual conf file,
- the debug file I generated with debug set to TRACE.
- The renderer conf file I've created
- the UMS.service file I've created, that allows me to control ums through systemctl (I had to change the extension to txt, in order to be able to upload it)
debug.log
(2.35 MiB) Downloaded 682 times
UMS.conf
(296 Bytes) Downloaded 599 times
(2.13 KiB) Downloaded 608 times
Chiron69
Post by Chiron69 »
One file did not upload..
UMS.txt
(220 Bytes) Downloaded 587 times
Chiron69
Post by Chiron69 »
Well, can anybody give me a hand?
The first problem is that I'm almost unable to navigate through the folders. Any parameter to tweak?
Thanks. :)
Chiron69
Post by Chiron69 »
I'm giving up.
I've discovered that my TV works out of the box with KODI acting as upnp server.
thank you for you help.
