PS4Pro & Strongish PC & Wifi 802.11A/C to stream UHD ?
Hello there,
before i even try it i want to know if the following hardware Combo will be able to stream flawless UHD content:
PS4 Pro with SSD(I don't know if it matters)
PC with 1080ti and i7-4790 3.6GHZ
both connected to WRT1900AC rounter with extended Antenna
the PC over lan and the PS4 over Wifi on the 5GHZ network with a relative close distance (around 30ft)
will the PC CPU will be the bottleneck ? should i do anything special to achieve the video quality im getting now from netflix / amazon video on 4k ?
Thanks for reading!
Thanks for reading!
