Tv dont see the UMC
Tv dont see the UMC
Windows and UMC show the Tv, but the Tv don't see UMC. I would be grateful if anyone would help.
- (223.71 KiB) Downloaded 429 times
Re: Tv dont see the UMC
Try to disable your firewall and/or antivirus to see if that makes a difference.
I specially make new rule for UMS and Java in firewall, this works but the movie play 1 min. and stops. Then i reinstall UMS, but UMS despaired from tv ...
It's not that simple take make the correct firewall rules. That's why you should try to disable it to see if that fixes the problem.
Why can't this stuff just work? My UMS is stuttering like crazy on 2 PCs on the same LAN same Router...50mbps internet... what the hell is going on?
