[Solved] Memory leak with Java 9
N3phastus
Post by N3phastus »
I usually would leave UMS running nonstop, but now with version 7.01, after 24 hours running, using it or not, memory goes up to 4 GB and CPU up to 80 / 90 % !!!
Did you build in a bitcoin miner in de latest version ???
Please fix it ASAP
cheers
N3
N3phastus
Re: Memory leak with Java 9
Post by N3phastus »
No one ???
ok, going back to 6.8
boss
Post by boss »
Yes, it is a problem in 7.01. Actually it was happening in earlier versions as well but just not as bad.
The issue is already known and the subject of a few other threads and the team is working on resolving the issue.
I run UMS 24/7 on a Gentoo Linux headless server. I found that turning off caching, whilst not stopping the issue, prolonged the time until UMS crashed.
My solution was to run a cron job every 2 days to restart UMS.
N3phastus
Post by N3phastus »
thank you Boss
We have a possible fix for this to test, are you interested N3phastus? If you let me know your operating system I will upload a test version
Java 9 has been discontinued and was only available for a short time so I recommend not using it anymore
