MKV files won't play on PS4 after clean install of 7.1
CurlyMJM69
Post by CurlyMJM69 »
I upgraded from 7.01 to 7.1 and mkv files no longer play on the PS4. The configuration is set the same for both versions. If I reinstall 7.01, the mkv files play. Again, have both versions configured exactly the same. I looked at the ps4.conf file for both versions and it is also exactly the same. Attached are log files from both versions.
ums_dbg_7.1.zip
(292.21 KiB) Downloaded 427 times
ums_dbg_7.01.zip
(307.55 KiB) Downloaded 435 times
