64 bit warnings now with Mojave
I'm not sure if the developers of UMS are aware yet, but Mojave is warning that UMS won't be supported in the future due to 64 bit support. I'm no coder, besides donations
what can be done to help support UMS to be converted to 64 bit?
Re: 64 bit warnings now with Mojave
UMS is already 64 bit since it's made in Java. It works with either 32 bit or 64 bit, it simply depends on what Java version you install. If you install a 64 bit Java, UMS is 64 bit as well. I'd encourage everyone with a 64 bit OS to also use 64 bit Java because 32 bit has some rather problematic restrictions when it comes to memory allocation and file mapping.
Thanks for letting us know about this, jecroft. Nadahar is right. If you are getting warnings about that despite using a 64-bit version of Java then it's a bug in Mojave, unless it is detecting 32-bit dependencies we are relying on
@SubJunk: If we're relying on 32 bit dependencies, that's a problem. What is that - tsMuxeR?
The macOS binaries we include are at http://universalmediaserver.com/svn/binaries/osx/
Most of them are probably 32-bit
Edit: One time I looked at these binaries (years ago now) there were still a lot of 32-bit Apple users so it wasn't feasible to update them. Now it might be different
Apple phased out 32 bit hardware in 2007. From what I can see all versions of OS X is 64 bit as long as the CPU is 64 bit. 10.6 was the last version to support 32 bit CPUs, so any version from 10.7 and up is exclusively 64 bit.
I can go through those files and see which need to be updated
I just updated to 10.14.3 and was prompted by Mojave with the 32bit warning again. How's the progress coming for updating the 32bit binaries?
I saw the warning last month too. I haven't done anything about it though
if you're interested you could help out by locating newer binaries
