Samsung 2018 Qled
Samsung 2018 Qled
Hey Guys
Does someone have a renderer file for a Samsung 55Q7FN?
All I tried so far (even the Samsung UHD one) gives me always an error on the TV (media type is not supported)
Re: Samsung 2018 Qled
Since nobody answered, try the samsung j55xx profile.
Also keep the #--transcode--# folder enabled, and try to play the file with the suffix "[No encoding]"
If the file plays with no Encoding, it means that the TV support that filetype and codec.
I am interested to work with you to make a new config for it, please attach logs so I can see how it identifies itself and I can get started
