[Solved] OSX Mojave - Dark Mode menu icon
bcbomb47
Post by bcbomb47 »
Are there any plans to edit the menu bar icon to work well in dark mode on Mojave? I think just removing the blue circle around the spiral shape (similar to what is in the top left of this forum page) would look really nice. Thanks!
--Brian
Re: OSX Mojave - Dark Mode menu icon
Good suggestion, I have created an issue for it here https://github.com/UniversalMediaServer ... ssues/1640
bcbomb47
Post by bcbomb47 »
Just wanted to follow up on this. I haven't seen any updates to the github issue. I might be able to create the ico file for you to use if needed. Thanks!
bcbomb47
Post by bcbomb47 »
I had some time during lunch. Here are the updated icons for OSX darkmode.
menubar_ums.zip
(4.53 KiB) Downloaded 618 times
Thanks for this, there is a pull request including your icons at https://github.com/UniversalMediaServer ... /pull/1860
bcbomb47
Post by bcbomb47 »
Awesome! You're welcome!
