Changed Renderer for Yamaha RX-V500D
newbietux
Contact:
Post by newbietux »
Hi guys,
thank you for your very good work. I use the 7.6.2 release on opensuse leaf 42.3.
Because I had problems with playing flac-files (is not a problem of the release! - it was a long time ago not correct) with the renderer-file for Yamaha RX-V500D (I posted it 2016-04-16), I experimented and tested various constellations of the options and changed the file.
Now I can play flac-files without problems.
Please take the updated renderer-file to your next release.
Yamaha-RXV500D.conf
changed renderer-file for yamaha RX-V500D because problems with flac-support
(1.25 KiB) Downloaded 605 times
Sami32
Re: Changed Renderer for Yamaha RX-V500D
Post by Sami32 »
Thank you :)
The following lines are unused in your configuration file, so removing them should not do any difference:
Supported = f:lpcm			m:audio/L16
Supported = f:mp3			m:audio/mpeg
Supported = f:wma			m:audio/x-ms-wma
Supported = f:wav			m:audio/wav
Supported = f:flac			m:audio/x-flac
Supported = f:aac			m:audi/x-m4a
Using "TranscodeAudio = WAV" or even deleting the "TranscodeAudio" line should give you better audio quality. Have you tried it?
Using "MediaInfo = true" should be a better choice but will ask more fine tuned lines of code.
newbietux, if those lines that Sami32 mentioned are removed from the file, there are no other changes. So it seems that this file is the same as the one we have, unless we have a bug where those "Supported" lines are being used when they shouldn't be
