UMS freezes while 'cleaning up database'
Hello, I'm recently having some problems with v7.6.2, where it freezes while 'cleaning up databases' with 100%.
It already happened 3 times, and only resolves when restarting the computer, and killing the javaw.exe process doesn't help.
When I open UMS, I can normally navigate the media server on my TV for a short period of time, but then it suddenly stops, and then the UMS is always showing the message below.
Logs/conf attached
Logs/conf attached
- (1.11 MiB) Downloaded 481 times
Re: UMS freezes while 'cleaning up database'
Thanks for this, it looks like we need to add some more logging to that cleanup feature, if I add some can I get you to re-test and post logs from the test version?
Did it start in 7.6 or 7.5?
sure! I believe it started in 7.6, not sure.
yeah, it seems to work, and the program starts way faster, thanksIn share settings, I turned off "scan shared folders at startup" and I "think" it stopped.
