Config files for LG SJ800V and Denon AVR-X2500H
fuggi
Post by fuggi »
All,
it took me a day to set up UMS with my LG SJ800V (webOS v5.8) and Denon AVR-X2500H. You will find the configuration files attached which work very well for me, though they might not be final. I hope they will serve you well, too.
This configuration is set up in such a way to work around the "audio codec undefined" issue reported earlier.
Best regards
fuggi
DenonAVR-X2500H.conf
Renderer configuration file for Denon AVR-X2500H
(2.24 KiB) Downloaded 715 times
LG-WebOS.conf
Renderer configuration file for LG SJ800V series
(2.82 KiB) Downloaded 729 times
