How to transcode?
Re: How to transcode?
UMS has difficulties transcoding to newer samsungs.
Have you enabled the #--transcode--# folder?
If you go into that, and play the "<filename>-[no encoding]"- option.. does the file play?
If it does, then it means your render.conf is not setup correctly
