Is there a way to adjust FFMPEG preset value???
valib
Re: Is there a way to adjust FFMPEG preset value???
Post by valib »
In the DefaultRenderer.cont there is written
# Overrides the FFmpeg custom options in UMS for this renderer. Default is
# empty, which means the UMS settings will be used.
# All setting for output formats, codecs, bitrate e.g. can be used except video,
# audio and subs mapping (-map).
# Do not use it to override -vf; use OverrideFFmpegVideoFilter instead.
# Default: ""
CustomFFmpegOptions =
