LG LM620S
sapsa
LG LM620S
Post by sapsa »
The Default Windows version of UMS show this tv as: LG Smart TV Upgrader (LGST600.conf)
The Default Linux version of UMS show this tv as: 42LA644V (LG-42LA644V.conf)
LG-42LA644V.conf
UserAgentSearch=LGE_DLNA_SDK
UserAgentAdditionalHeaderSearch=42LA644V
LGST600.conf
My TV aint 42LA644V but it looks like that version 3.+ on linux dont check the "additionalHeader" Just use the first file from renders/
This can be fix using "ignored_renderers" in conf, but this should work similar to windows version.
Is there any way to check what codes my TV support (its not on page/manual, only containers like avi/mkv)
Or is there a folders with variouse formats of video/audio so i can plug them on USB to tv and check file by file?
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
DeFlanko
Contact:
Re: LG LM620S
Post by DeFlanko »
http://www.lg.com/es/television/lg-42LM620s-3d
Looks if those formats can be played from the usb then I'm sure they can be streamed to it.
Case in point for the LG-42LA644V.CONF:
StreamExtensions=asf,wmv,avi,divx,mp4,m4v,mov,3gp,3g2,mkv,ts,trp,tp,mts,m2ts,vob,mpg,mpeg,mp3,jpg,jpeg,jpe,jps,mpo
you could technically use that CONF to stream to it. what happens when you try?
Optimus_prime
Re: LG LM620S
Post by Optimus_prime »
Also to find out over the network what the device supports you can do this:
1. Install Intel UPnP tools - LINK
2. run Device Spy
3. It should list all your UPnP device and among them your device (eg TV, console, etc)
4. Expand the device's tree and find service: urn:upnp-org:serviceId:ConnectionManager:1
5. Expand that and double click on GetProtocolInfo(...).
6. And you need to use the the result in field Sink.
Or Alternatively you may find you device here via a search for it's supported features via DLNA Product Search
Reason: Added the Link; and screenshots of what to look for... (assuming thats what to do..) :)
DeFlanko
Contact:
Re: LG LM620S
Post by DeFlanko »
I hope these help :)
sapsa
Re: LG LM620S
Post by sapsa »
at page those are cointainers only and not codes - some files just dont work when using the la644v.conf, but after chainging to lgst600 those files work ok.
For example: some files plays video but not audio, other dont play at all.
I will check that spy thing!
edit: about the link to dlna, it gave me a poor info because only which mpeg are supported, there isin't any info about outer containers/codes on that dlna page. The spying app gave more alot more info - will update my render conf.
sapsa
Re: LG LM620S
Post by sapsa »
Best I could get :-)
# Profile for LG *LM620S/ZE
# RENDERER RECOGNITION
RendererName=LG 55LM620S-ZE
#full string: Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.6.0
#UserAgentAdditionalHeader=Linux/2.6.35
#UserAgentAdditionalHeaderSearch=Linux/2.6.35
# BASIC CAPABILITIES
Video=true
Audio=true
Image=true
# DLNA SETTINGS
SeekByTime=true
DLNALocalizationRequired=false
# MEDIAINFO
MediaInfo=true
CreateDLNATreeFaster=false
# TRANSCODING AND MUXING CAPABILITIES
TranscodeVideo = MPEGPSAC3
#by? WAV
TranscodeAudio=LPCM
DefaultVBVBufSize=false
#ignored by setting mediainfo = true
MuxH264ToMpegTS=true
MuxDTSToMpeg=true
WrapDTSIntoPCM=true
MuxLPCMToMpeg=true
MaxVideoWidth=1920
MaxVideoHeight=1080
MaxVideoBitrateMbps=0
MimeTypesChanges=video/avi=video/x-divx
TranscodeExtensions=
StreamExtensions=
#not ignored
H264Level41Limited=true
TranscodeAudioTo441kHz=true
TranscodeFastStart=true
TranscodedVideoFileSize=0
TranscodedVideoAudioSampleRate=48000
ForceJPGThumbnails=false
ShowAudioMetadata=true
ShowSubMetadata=true
DLNAOrgPN=true
# IMAGES
AutoExifRotate=true
# SUPPORTED MEDIA FORMATS
# Supported video formats:
Supported = f:mpeg|mpegps|mpegts|mkv   v:mpeg1|mpeg2|mp4|h264   a:lpcm|mpa|wav|acc|ac3   m:video/mpeg
Supported = f:avi|divx            v:mp4|divx|mjpeg         a:mp3|lpcm|mpa|wav|acc|ac3   m:video/x-divx   qpel:no   gmc:0
Supported = f:mp4                 v:mp4|h264               a:mp3|lpcm|mpa|wav|acc|ac3   m:video/mp4
Supported = f:wmv                 v:wmv|vc1                a:wma                m:video/x-ms-wmv                   n:2
Supported = f:asf                 v:wmv|vc1                a:wma                m:video/x-ms-asf                   n:2
# Supported audio formats:
Supported = f:wav     n:6   m:audio/wav        a:dts|lpcm     s:44100
Supported = f:wav     n:2   m:audio/wav                       s:44100
Supported = f:aac     n:2   m:audio/x-m4a      a:(?!alac).+
Supported = f:mp3     n:2   m:audio/mpeg
Supported = f:wma     n:2   m:audio/x-ms-wma
# Supported image formats:
Supported = f:jpg    m:image/jpeg
