Web folder on navigation settings
Re: Web folder on navigation settings
Unchecking the "Enable External Network" option in the General settings tab will remove the web folder
It's not something I use so have it disabled anyway, but as far as I know it is for Internet Streaming and youtube which is accessed in the web folder if set up correctly. If you don't need it won't turn off anything else if disabled.
