[Solved] Samsung UHD 2019 - mkv not playing (EAC3) - transcode
atamariya
Re: Samsung UHD 2019 - mkv not playing (EAC3) - transcode
Post by atamariya »
When a particular files doesn't play, it indicates a supporting line is missing in the renderer config file. You can try adding the line and share it here so that it may be included in the code to help others having the same renderer. In most cases however, it is just easier to browse into the transcode folder and pick a combination that does work. Transcode folder lists all possible combinations of codec that UMS thinks are supported by the renderer.
Hi Sefer,
Thanks for the logs. Unfortunately they need to be made in TRACE mode to be useful. Instructions are at https://www.universalmediaserver.com/fo ... ?f=9&t=556
Thanks for confirming it is working. I really want to make a better GUI with dropdowns for the subtitles options. Maybe one day :)
