WDTV Plus
danielt
WDTV Plus
Post by danielt »
When playing a .m4v file with a DTSMA audio stream, if I use the default option, it is coming across as an AAC audio. If I go into the transcode folder and use any three of the options (TsMuxer, Mencoder, FFMPEG), I get the correct audio (DTSMA).
I've tried going into the conf file for WDTV and add .m4v to the force streaming, and that does fix the problem. However, I'd like to correct the conf file so that it is 'working as intended'... I've tried adding DTSHD to the acceptable audio formats, but not sure I did it correctly, or if that was the right change.
The log files attached capture:
Playing The Hobbit with default selection
Playing The Hobbit by forcing tsMuxer from transcode folder.
Playing The Hobbit by forcing mencoder from transcode folder.
Playing The Hobbit by forcing ffmpeg from transcode folder.
Thanks in advance!
Daniel
log pack
(638.79 KiB) Downloaded 481 times
danielt
Re: WDTV Plus
Post by danielt »
It looks like if I change the renderer order and make FFMPEG the primary, then everything works fine.
danielt
Re: WDTV Plus
Post by danielt »
danielt wrote:It looks like if I change the renderer order and make FFMPEG the primary, then everything works fine.
Except this breaks streaming to the Xbox360. If FFMPEG is primary, then streaming DVD type material spits and stutters. If I flip it back to mencoder first, it will stream anything to the Xbox. arghhh...
Is there any way to set default transcoder by renderer?
danielt
Re: WDTV Plus
Post by danielt »
danielt wrote:When playing a .m4v file with a DTSMA audio stream, if I use the default option, it is coming across as an AAC audio. If I go into the transcode folder and use any three of the options (TsMuxer, Mencoder, FFMPEG), I get the correct audio (DTSMA).
Thanks in advance!
Daniel
Did some experimenting on the original problem last night. If I use a mkv container with the same video/audio stream, it plays fine using the default settings.
It is only receiving the DTS core, though.
If I stream using an mp4 container with the same video/audio stream, I get the full DTSMA 4.5MBit stream if I select ffmpeg in the transcode folder.
