Version 9.6.2 released
General:
This is mainly a followup bugfix release.
We are busy preparing our next beta which improves, stabilizes and extends our metadata, allowing for things like recommendations, genres, ratings from major sources, etc. as well as remote access.
Download:
Windows, macOS and Linux: Our front page or our official mirrors
Docker: docker pull universalmediaserver/ums
Changes since 9.6.1
  • General:
    • Fixed broken browsing on some renderers
    • Fixed broken transcoding on renderers with KeepAspectRatio enabled
    • Improved support for web interface on iOS (thanks, Jeff Puls!)
  • Renderers:
    • Updated support for external subtitles on VLC for Desktop (thanks, JuanPZ!)
    • Russian (94%)
  • Dependency updates:
    • netty from 4.1.50 to 3.10.6
Notes:
  • Windows has limited support from XP onwards, but full support is for Windows 7 onwards
  • macOS 10.10+ is fully supported
pipin
Re: Version 9.6.2 released
Post by pipin »
Regards,
Jens
JuanPZ
Post by JuanPZ »
Nice!
Now the subtitles are working without any problem on VLC!
Thanks!
Fixed the problems for me too
Thanks for the feedback, really nice thing to see :)
knicknak
Post by knicknak »
Similar problems as last time:
Running 9.6.1. and didn't get an auto-update notice for 9.6.2
If I manually hit "check for updates" it doesn't find 9.6.2
Have to close and open UMS to get it to find the update.
knicknak wrote: Tue Jun 16, 2020 2:03 pm Similar problems as last time:
I've made an issue for that at https://github.com/UniversalMediaServer ... ssues/2110
