[FIXED] Issues with Avisynth (error 800288E1)
Locked
Audioboxer
Post by Audioboxer »
Whenever I try to use Avisynth/Mencoder or Avisynth/FFmpeg I always get this error on the PS3
This content cannot be played. (800288E1)
The log always shows (with ffmpeg.exe as well)
12-09 02:53:46 Process C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe has a return code of 1! Maybe an error occurred... check the log file
Every other transcoding engine works great, it's whenever I try anything with Avisynth. I've done clean installs and also tried toggling off the Tru Motion/GPU and multithreading options. Happens with absolutely every kind of video file (mkv/avi/mp4).
Any ideas? Thanks
Re: Issues with Avisynth (error 800288E1)
Hi Audioboxer, thanks for reporting this. Unfortunately I can't reproduce the error myself so I need your logs. Please follow the instructions in my signature
Audioboxer
SubJunk wrote:Hi Audioboxer, thanks for reporting this. Unfortunately I can't reproduce the error myself so I need your logs. Please follow the instructions in my signature
Hey Subjunk, running with Avisynth/Mencoder, tried two separate files. Cheers
I can provide Avisynth/FFmpeg as well if needed.
(69.04 KiB) Downloaded 544 times
Can you please try to install the latest K-Lite Mega Codec Pack? AviSynth is the only one of our engines that relies on codecs being installed
Audioboxer
SubJunk wrote:Can you please try to install the latest K-Lite Mega Codec Pack? AviSynth is the only one of our engines that relies on codecs being installed
K-Lite Mega Codec pack worked 8-)
Is there anything lighter in terms of codec packs? I guess it is pretty light anyway.
Re: [FIXED] Issues with Avisynth (error 800288E1)
K-Lite has some non-mega variants you can try too, but I always just use mega so it can handle any weird file I may have :)
Locked
