Cloned my drive to a new one. Zipped and moved media folder to now-wiped old drive. UMS cannot be found on other devices
Acxelion
Post by Acxelion »
I recently bought an SSD to speed up my boot time, but since SSDs are expensive, I wiped my old drive and moved my media folder back to my old one. However, after changing the media folder in the settings and trying uninstalling and reinstalling UMS, it cannot be found on other devices on the network(TV, Xbox One, phone). I did some quick google searches but I couldn't find a thread that clearly addressed this issue.
ums_dbg_2020-11-19-01-35.zip
Debug files from my UMS server after reinstallation
(301.63 KiB) Downloaded 306 times
Re: Cloned my drive to a new one. Zipped and moved media folder to now-wiped old drive. UMS cannot be found on other dev
The most common reason for when UMS can't find any renderers on a network is that it is using the wrong network interface. It is usually because there is a VPN installed which creates a virtual interface and that can be incorrectly selected as default.
In General Settings tab, under Network Settings (Advanced) select your physical interface in the "Force networking on Interface" drop down.
Acxelion
Post by Acxelion »
How would I figure out what network interface to set UMS to?
EDIT: I guess I found the right interface? I tested some and now its showing on my phone at least.
