UMS Showing Double Subtitles
Hi All,
I'm running UMS 10.4.1 on MacOS 10.14.6.
I'm running into an issue where the file I'm trying to play (on Media Player for Xbox Series X) contains two english subtitles. Having scoured the forums for this problem, the solution generally is to enable the transcode folder and select which subtitles you want. In my transcode folder I see both subtitle options separated, however, if I select either of these options, BOTH subtitles are still encoded... I'm extremely confused why this is happening. If I play this file on my computer with VLC, I can select between the subtitles as you normally could. Any help would be appreciated. Thanks!
- ums_dbg_2021-05-06-14-50.zip
- (321.75 KiB) Downloaded 750 times
