[Solved] Fully Played Action
Cardician
Post by Cardician »
I have performed a clean install of UMS v10.4.1 and have noticed the Fully Played Action is not working.
Re: Fully Played Action
Please attach logs after reproducing
Cardician
Post by Cardician »
Hi SubJunk
Attached is the debug file as requested.
debug.log
(2.54 MiB) Downloaded 803 times
lonix
Post by lonix »
Hello Kardiker,
I had the same problem. After I marked "navigation settings" -> "enable the media library" it worked again.
I hope this can solve your problem too.
best regards
lonix
Please let me know if that fixes it
Cardician
Post by Cardician »
SubJunk wrote: Tue May 11, 2021 8:08 pm Please let me know if that fixes it
Unfortunately the "enable the media library" option made no difference.
Cardician
Post by Cardician »
Cardician wrote: Tue May 11, 2021 10:02 pm
I have just performed a clean install of v10.5.0 and the Fully Played Action feature is still not working.
Cardician
Post by Cardician »
laurenince525 wrote: Wed May 12, 2021 9:34 pm I am using express vpn for netflix. it also works with hulu, HBO and BBc player
I am using UMS to stream from my PC, not a streaming service.
Also from experience, all streaming services indicate which episodes you have watched.
Sorry for your troubles with this feature. I agree it is core functionality that needs to work.
Can you please confirm that the "Monitor played status of files" checkbox is enabled for the folder you are playing from? That can be found on the "Shared Content" tab
lonix
Post by lonix »
I can confirm that the checkbox "Monitor played status of files" is ticked -> works on my system
lonix
