tv without dlna
kreon28
tv without dlna
Post by kreon28 »
I am going to change my tv to some newer model. I checked some of the most interesting for me: like LG OLED55B13LA or Philips 55OLED805/12.
I have found in the specification that these models do not support Dlna. Is there a possibility to use UMS with them somehow?
Re: tv without dlna
I'm not 100% sure but is a good chance that UMS will work fine even if you don't see Dlna mentioned in the specs.
LG uses WebOS which supports that, my parents have a similar model and UMS works fine. A quick look at the specs for Phillips mentions a load of supported formats so that should be fine too.
To make sure though, try and download the manuals as it will show the full specs.
