Re: Version 10.12.0 released
sdabrams3
Post by sdabrams3 »
Subjunk,
Here is the requested log files your were requesting. Thanks for looking into this issue.
ums_dbg_2021-09-21-18-29.zip
(255.63 KiB) Downloaded 35 times
Scott
I'm not exactly sure what your issue with thumbnails is or what Subjunk will be looking for in your logs but I do see that none of your shared folders have "Monitor played status of files" enabled so they will not be marked as played and have their thumbnail updated.
Try enabling it for each folder and see if that makes a difference.
sdabrams3
Post by sdabrams3 »
Ok was not aware of that - let me try that tonight. Thanks for your post.
sdabrams3
Post by sdabrams3 »
"Monitor played status of files" enabled resolved my issues. thank you
Scott
