Amazon Fire TV and VLC 3.3.4 ....
SO far I ahve done this as follow :
Then afterwards it freezes, and I have noticed if I use this :
Then the thing doesn't see the UMS server half of the time? Could this be fire wall or networking error ? I am baffled and unsure I need massive help writting this Amazon Fire TV for VLC conf file anyone with any help would be apprciated.
Please post any and all thing below I will read them and respond as fast as I can.
Thank you,
sweldon001
RendererName = Amazon Fire TV Stick VLC Player
# This renderer has sent the following strings:
# User-Agent=Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6281)
# User-Agent=Linux/4.4.120+, UPnP/1.0, Portable SDK for UPnP devices/1.6.19
# User-Agent: VLC/3.3.4, LibVLC/3.3.4, Amazon FireTV
# User-Agent: VLC/3.0.12.1, LibVLC/3.0.12.1, Amazon Fire TV
# User-Agent=6.2.9200 2/, UPnP/1.0, Portable SDK for UPnP devices/1.6.19 for VLC 32-bit version 2.2.4
# User-Agent=6.1.7601 2/Service Pack 1, UPnP/1.0, Portable SDK for UPnP devices/1.6.19 for VLC 64-bit version 2.2.4
# User-Agent=Linux/3.13.0-68-generic, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
# User-Agent=Darwin/12.5.0, UPnP/1.0, Portable SDK for UPnP devices/1.6.19
# This could be false positive for other APPs using the Portable SDK
UserAgentSearch = Linux\/\d\.\d+.\d+\+{0,1}, UPnP\/\d\.\d, Portable SDK for UPnP devices\/1\.\d\.\d{1,2}
# Loading priority is set to 2 to give priority to this configuration and
# override the "Google-Android.conf" and the ""Google-Android-Chromecast.conf"
LoadingPriority = 2
TranscodeVideo = MPEGTS-H264-AAC
TranscodeAudio = WAV
DefaultVBVBufSize = true
SendFolderThumbnails = false
SupportedVideoBitDepths = 8,10
MimeTypesChanges = video/mpeg=video/mp4
CustomFFmpegOptions = -async 1 -fflags +genpts -c:a libmp3lame -ac 2 -b:v 35000k -bufsize 35000k -f matroska
MediaInfo = true
# Supported video formats:
Supported = f:avi m:video/avi
Supported = f:flv m:video/x-flv
Supported = f:mkv m:video/x-matroska
Supported = f:mov m:video/quicktime
Supported = f:mp4 m:video/mp4
Supported = f:mpegps|mpegts m:video/mpeg
Supported = f:rm m:application/vnd.rn-realmedia-vbr
Supported = f:wmv m:video/x-ms-wmv
# Supported audio formats:
Supported = f:dts m:audio/vnd.dts
Supported = f:flac m:audio/flac
Supported = f:oga m:audio/ogg
StreamExtensions=mkv,hdmov,hdm,flac,fla,dvix,mpts,ts,flv,3gp,mp3,dts,ogg,asf,asx,m2v,mp4,mpg,mpeg,avi,mov,wmv
SupportedExternalSubtitlesFormats = ASS,PGS,SUBRIP,VOBSUB
SupportedInternalSubtitlesFormats = ASS,PGS,SUBRIP,VOBSUB
# Profile for the VLC desktop application. VLC 2.x has poor DLNA implementation
# and may not work very well. VLC 3.x improving this a lot.
RendererName = VLC for FireStick
UserAgentSearch = Portable SDK for UPnP devices\/1\.\d\.\d{1,2}
Thank you,
sweldon001
Re: Amazon Fire TV and VLC 3.3.4 ....
The DBG FIles... Before Amazon Fire TV VLC runs :
The DBG Files for After Amazon FIre TV For VLC runs:
I almost forgot I am running Windows 11 The test version thru Microsoft.
- ums_dbg_2021-10-07-07-39.zip
- (67.25 KiB) Downloaded 142 times
also this is the conf file I modified from this forum to dectect and possibly connect and run Amazon FIre TV For VLC conf file.
I found the ffmpeg64.exe was corrupt.. so i downloaded ffmpeg 4.4 and renamed it ffmpeg64.exe and placed it in proper location. it all functions normally now.
as proof it fully work here is dbg files as well
As I wrote in the render support thread (https://www.universalmediaserver.com/fo ... =5&t=14124), I had at the beginning issues with stucking and freezing because of the WiFi speed. Videos with let's say 480p played smooth, but higher resolutions...
Another issue came up when I updated to the latest version 10.12.0 of UMS. But this was more like video seeking issue. +/- 10 sec. doesn't work anymore. So I downgraded to 10.10.1 as quick fix. Don't know what's the reason for this.
In addition, the config selection by the user agent is very weak in my opinion. When I leave all configs provided by installer where they are, my FireTV Stick will be recognized as Chrome OS.
