ERROR Unexpected error in RemotePlayHandler.handle(): Index: 0, Size: 0 - UMS 10.15.0
When I try to use the web interface to play a video I am getting "ERROR Unexpected error in RemotePlayHandler.handle(): Index: 0, Size: 0" when I play anything that is not .mp4
Tried installing all sorts of codecs on the machine I am trying to open it, but with no luck.
Here is the log attached.
- ums_dbg_2022-02-05-23-04.zip
- (119.59 KiB) Downloaded 809 times
Re: ERROR Unexpected error in RemotePlayHandler.handle(): Index: 0, Size: 0 - UMS 10.15.0
Any idea what might be the problem?
It sounds like a bug. Either wait for a new version with a fix or try an older version.
Perhaps it is a bug.
I wonder if anyone else experiences the same issue?
Just find out where the problem comes from.
If the checkbox "Show the Media Library folder" under Navigation Settings is not checked, then the problem starts. As soon as I switch it on and clear the cache, the problem disappears.
No idea why it is happening, but that is how to solve it.
Thanks for sharing this largan, the fix will be in our next release
Re: [Solved] ERROR Unexpected error in RemotePlayHandler.handle(): Index: 0, Size: 0 - UMS 10.15.0
I think this has already been fixed in 10.16.0, can you try it?
