10.16.0 [Linux] ffmpeg hwaccel issue
thedude
Post by thedude »
Even though there is a custimized ffmpeg path configured, the hwaccel check will not honor this:
DEBUG 2022-02-20 10:33:03.315 [main] Starting /usr/bin/ffmpeg -hwaccels
DEBUG 2022-02-20 10:33:03.319 [main] Unix process ID (/usr/bin/ffmpeg): 1331
DEBUG 2022-02-20 10:33:03.819 [ffmpeg-1-2] ffmpeg version 4.4-6ubuntu5 Copyright (c) 2000-2021 the FFmpeg developers
DEBUG 2022-02-20 10:33:03.820 [ffmpeg-1-2] built with gcc 11 (Ubuntu 11.2.0-7ubuntu1)
DEBUG 2022-02-20 10:33:03.821 [ffmpeg-1-2] configuration: --prefix=/usr --extra-version=6ubuntu5 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libavutil 56. 70.100 / 56. 70.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libavcodec 58.134.100 / 58.134.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libavformat 58. 76.100 / 58. 76.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libavdevice 58. 13.100 / 58. 13.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libavfilter 7.110.100 / 7.110.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libswscale 5. 9.100 / 5. 9.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libswresample 3. 9.100 / 3. 9.100
DEBUG 2022-02-20 10:33:03.829 [ffmpeg-1-2] libpostproc 55. 9.100 / 55. 9.100
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] Hardware acceleration methods:
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] vdpau
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] cuda
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] vaapi
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] qsv
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] drm
DEBUG 2022-02-20 10:33:03.844 [ffmpeg-1-1] opencl
BR
debug.log
(43.58 KiB) Downloaded 798 times
