Version 11.0.0-a1 released
General:
This release adds more rich data like logos and backgrounds to TV series, movies and episodes in the web interface, improves device detection, video playback and seeking, improves API metadata matching, and more!
Download:
This release is available on our front page.
Changes compared to v10:
  • General:
    • Uses image backgrounds and logos for movies, TV series and episodes on the web interface
    • Web interface switches between dark and light themes in Media Library based on background images
    • Automatic quality adjustment on web interface, with optional manual settings
    • Improved video forward-backward positioning in videos via the web video player
    • Improved web interface design
    • Improved web video player design
    • Improved API metadata matches for TV series
    • Added HLS video option which may improve support for transcoding via some renderers like Philips TVs
    • Log splitting/zipping (#2608)
    • Implemented network state scanner
    • Show the addresses of servers on the Status tab (#2372)
    • Allow to set the log level of FFmpeg in its engine settings in the desktop UI (#2677)
    • Increased maximum memory limit on macOS to match Windows
    • Fixed Restart server when network interface becomes available (#2615)
    • Fixed Network Interface not found (#1485)
    • Fixed GetProtocolInfo not being recieved (#2338)
    • Fixed Font scaling issues on some elements of the GUI for some users (#2549)
    • Fixed UMS doesn't free DLNA ports after closing (#739)
    • Fixed Service wrapper for Windows doesn't work with 64 bit JVM (#767)
    • Fixed Deinstallation does not remove autostart entry for wrapper.exe (#2343)
    • Fixed Attempt to remove medias.lock on install/startup (#2838)
    • Fixed Media Library no longer populated and startup scan slowness (#2826)
    • Fixed Could not open the default web browser: The BROWSE action is not supported on the current platform! (#2725)
  • Renderers:
    • Samsung 2021 TVs use HLS transcoding
  • Dependencies:
    • Added x64 windows service wrapper
    • Fixed support for latest Maven versions
    • Replaced Cling with JUPnP
    • Bump checkstyle from 9.3 to 10.2
    • Bump JRE from 8u332 to 17.0.3
    • Bump Video.js from 7.13.3 to 7.19.2
Support us:
chickyboom
Re: Version 11.0.0-a1 released
Post by chickyboom »
Same as 10.20.0 for me, "no content found" on my samsung tv. (10.19.0 is good.)
That's fixed in 10.21.1 and 11.0.0-a2 which are in the pipeline to be released today.
You can also fix it by enabling the cache on the Navigation Settings tab, since that bug only affects users with that setting disabled.
