Profile for Samsung Q60 series
just changed to a Samsung Q60 and am struggling with the profile.
Video Specs can be found here:
https://developer.samsung.com/smarttv/d ... tions.html
Trying to adjust the Samsung-TV-2021-1.conf profile but so far not everythings works perfectly. Is anyone able to help?
22TV_STANDARD1 (UHD)
File
Extension
Container Video Codec Resolution Frame Rate
(fps)
Bit Rate
(Mbps)
Audio Codec
*.avi
*.mkv
*.asf
*.wmv
*.mp4
*.mov
*.3gp
*.vro
*.mpg
*.mpeg
*.ts
*.tp
*.trp
*.flv
*.vob
*.svi
*.m2ts
*.mts
AVI
MKV
ASF
MP4
3GP
MOV
FLV
VRO
VOB
PS
TS
H.264 BP/MP/HP 4096x2160 4096x2160: 30
3840x2160: 60
60 AC3
LPCM
ADPCM(IMA, MS)
AAC
HE-AAC
WMA
DD+
MPEG(MP3)
MPEG-H
AC-4
OPUS
G.711(A-Law, µ-Law)
HEVC (H.265 Main10) 4096x2160 60
(3840x2160:120)
80
Motion JPEG 3840x2160 30 80
MPEG-4 SP/ASP 1920x1080 60 20
Window Media Video 9 (VC-1)
MPEG-2
MPEG-1
Microsoft MPEG-4 version 1/2/3 30
Window Media Video 7 (WMV1)/8 (WMV2)
H.263 Sorenson
VP6
AV1 3840x2160 60 40
*.webm WebM VP8 1920x1080 60 20 Vorbis
VP9 (Profile 0/2) 3840x2160 80
AV1 3840x2160 40
*.rmvb RMVB RV8/9/10 (RV30/40) 1920x1080 20 RealAudio 6
Table 4. 22TV_STANDARD1(UHD) video specifications
General Limitations
Media with errors cannot be played with some codecs.
Media cannot be played if the file is corrupted or the information in the container is wrong.
Media with higher bit or frame rate than specifications can cause video or audio playback to stall.
Seek (jump) function is not supported if the index table is corrupted.
Network streaming content playback can be choppy, depending on network status.
Some USB and digital camera devices can be incompatible with the player.
Videos playing on the panel can be shown at lower frame rates than the original sources.
Video Decoder Limitations
H.264 FHD: Level 4.2 supported (FMO/ASO/RS not supported).
H.264 UHD: Level 5.1 supported, seamless resolution change supported up to 3840x2160.
HEVC FHD: Level 4.1 supported.
HEVC UHD: Level 5.1 supported, seamless resolution change supported up to 3840x2160.
HEVC: Supported only for MKV/MP4/TS containers.
VC-1 AP L4: Not supported.
GMC 2 and higher: Not supported.
Audio Decoder Limitations
WMA 1: Not supported.
WMA 9 Pro: Lossless and Voice not supported.
WMA 10 Pro: 5.1 channel supported.
QCELP and AMR NB/WB: Not supported.
MPEG-H: Only supported on target devices for South Korea.
Vorbis: 5.1 channel supported.
DD+: 5.1 channel supported.
Sampling rates 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, and 48 kHz supported, depending on codec.
Important
The DTS Audio codec is not supported on 2022 TVs. For smooth playback, if a DTS Audio track is part of your manifest, make sure other audio tracks can be selected.
File
Extension
(fps)
Bit Rate
(Mbps)
Audio Codec
*.avi
*.mkv
*.asf
*.wmv
*.mp4
*.mov
*.3gp
*.vro
*.mpg
*.mpeg
*.ts
*.tp
*.trp
*.flv
*.vob
*.svi
*.m2ts
*.mts
AVI
MKV
ASF
MP4
3GP
MOV
FLV
VRO
VOB
PS
TS
3840x2160: 60
60 AC3
LPCM
ADPCM(IMA, MS)
AAC
HE-AAC
WMA
DD+
MPEG(MP3)
MPEG-H
AC-4
OPUS
G.711(A-Law, µ-Law)
(3840x2160:120)
80
MPEG-2
MPEG-1
H.263 Sorenson
VP6
AV1 3840x2160 60 40
AV1 3840x2160 40
General Limitations
Important
Samsung-Q60B.conf
- (12.18 KiB) Downloaded 1322 times
