Stops playing - intermittant
Im playing a video when UMS just immediately stops playing
The Log just says:
14:03:03 INFO Setting video resolution to: 1920x1080, your Video Scaler setting
14:03:14 INFO Process /usr/bin/mencoder has a return code of 139! Maybe an error occurred... check the log file
14:03:49 INFO Stopped playing Return of the Dragons of Wisdom pt1 - with Mark Passio (720p_25fps_H264-192kbit_AAC).mp4 on BRAVIA KDL-40CX520
I have tryed with different .MP4 files, including ones with extremely small/low BitRates (checked with MediaInfo) to see if that makes any differance
UMS Version: 11.5.0
OS: Linux - Opensuse Tumbleweed
Had this same problem on previous 2 versions as well
Log file provided in attachment
Please Help !
The Log just says:
UMS Version: 11.5.0
Please Help !
- ums_dbg_2022-10-29-14-04.zip
- (19.77 KiB) Downloaded 1595 times
