ums Won't regonize ps3 as a renderer.
ok, i have done some diggin and still haven't found solution for this.
UMS won't regonize my ps3 as a renderer, debug log says that access granted "ps3 ip here", but still it won't show as a renderer.
there's been few times when everythings been working just right and ps3 have been found as a renderer, but most of the time it i have this "no renderer" problem.
Thank you for your time.
Edit: log file didn't show my OS right so.. it's Windows 8 pro 64bit
- Log's
- (15.94 KiB) Downloaded 485 times
Re: ums Won't regonize ps3 as a renderer.
What was the reason you set the UMS and ? If there is no specific reason please leave these settings empty.
Also please install the latest Java version.
port =6001
ip_filter =192.168.10.47
i've been trying with default setting and with slightly customized settings, but still i get no renderer found.
updated java too, it didn't help.
i have double checked firewall settings and sharing settings. Tried with and without firewall/antivirus. tried with "whitelist ip" and without "whitelist". tried with default renderer as ps3 and with all renderers settings.
It's just weird that couple of times its been working fine, but after i have restarted either pc or ps3 or both, ums won't find any renderers.
- Optimus_prime
Are you running any Anti-Virus or Firewall software? Check that UMS is being allowed in Windows Firewall as well.
checked windows firewall and it's not blocking ums and after i checked it couple of days ago i turned it off as i don't really need it.
