Websettings not working
inovatech
Post by inovatech »
Hi!
(UMS V13.0.1)
if i start UMS there is the Icon "Web Setting" grey... i can´t select it!
What can i do to setup the Web-Settings ?
Thank you!
Re: Websettings not working
Double clicking the try icon should bring up the web settings, or you can go to http://localhost:9001/
If this is not working then something has failed and will need logs to see why, see the section in red above.
