Kodi 19.3 Showing episode titles instead of File Names
Havok1769
Post by Havok1769 »
Currently running Kodi 19.3 on my ShieldTV,
I am starting to use Kodi again after not using it for years. My Files are appearing via their episode titles instead of the file names that they are saved as on my NAS. This is causing them to be totally out of order.
I went into the Kodi settings and turned off the "Replace file names with library titles" option, I've tried cleaning the library and restarting many times to no help.
Was informed on the Kodi forums that as UMS is added as a UPnP device the issue is on the UMS side
Current Setup:
Kodi 19.3 on Shield TV
Files saved on Sonolgy NAS
Universal Media Server on PC added as UPnP device in Kodi (confirmed "prettify filenames" turned off)
Re: Kodi 19.3 Showing episode titles instead of File Names
If prettify filenames is turned off then there should be no change to the filenames.
UMS will sort the files before sending the list to the renderer and there are various options to do that in the settings and there is also an option to Ignore articles "a" and "the" while sorting. You can also just set it to no sorting.
To see exactly what is happening and what is being sent to Kodi I will need to see logs, follow the link in my sig.
Havok1769
Post by Havok1769 »
mik_s wrote: Fri Jan 13, 2023 5:21 am If prettify filenames is turned off then there should be no change to the filenames.
Here is the trace log.
The line in the Log that shows the video starting has the full file name including the episode title but Kodi displays all files with only the title names
ums_dbg_2023-01-13-17-19.zip
(862.95 KiB) Downloaded 944 times
I'm not an expert at this but from what I see the filenames are being sent unaltered but also UMS is supplying metadata in UPnP like
the episodeSeason, episodeNumber, seriesTitle, programTitle along with other metadata and Kodi is using this data to display the file list.
There must be a way in Kodi to ignore these fields and just display the filenames.
I have not used Kodi but would assume it has great support for using the metadata to sort things correctly. See if there is a sort by season/episode option somewhere instead of sorting by episode name.
TRACE 2023-01-13 17:17:24.273 [jupnp-netty-worker-15] net.pms.network.mediaserver.nettyserver.RequestV2 The unescaped <Result> sent to Kodi (192.168.50.4) [Kodi] is:
<DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:pv="http://www.pv.com/pvns/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/">
  <item id="213" parentID="212" restricted="1">
    <dc:title>Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE {English subtitles}</dc:title>
    <dc:date>2022-09-06T21:32:03</dc:date>
    <upnp:episodeSeason>6</upnp:episodeSeason>
    <upnp:episodeNumber>1</upnp:episodeNumber>
    <upnp:seriesTitle>Rick and Morty</upnp:seriesTitle>
    <upnp:programTitle>Solaricks</upnp:programTitle>
    <upnp:playbackCount>5</upnp:playbackCount>
    <upnp:lastPlaybackTime>2022-12-06 17:57:41.056</upnp:lastPlaybackTime>
    <upnp:lastPlaybackPosition>0:00:04.000</upnp:lastPlaybackPosition>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" bitrate="531800" colorDepth="8" duration="0:22:19.350" framerate="24p" protocolInfo="http-get:*:video/x-matroska:DLNA.ORG_PN=AVC_MKV_MP_HD;DLNA.ORG_OP=01" resolution="1920x1080" size="712267318">http://192.168.50.2:5001/get/213/Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_RES_320_180;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="320x180" size="12537">http://192.168.50.2:5001/get/213/thumbnail0000JPEG_RES320x180_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.jpg</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="320x180" size="12537">http://192.168.50.2:5001/get/213/thumbnail0000JPEG_SM_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.jpg</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="160x90">http://192.168.50.2:5001/get/213/thumbnail0000JPEG_TN_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.jpg</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/png:DLNA.ORG_PN=PNG_LRG;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="320x180">http://192.168.50.2:5001/get/213/thumbnail0000PNG_LRG_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.png</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/png:DLNA.ORG_PN=PNG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="160x90">http://192.168.50.2:5001/get/213/thumbnail0000PNG_TN_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.png</res>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="JPEG_SM">http://192.168.50.2:5001/get/213/thumbnail0000JPEG_SM_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.jpg</upnp:albumArtURI>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="JPEG_TN">http://192.168.50.2:5001/get/213/thumbnail0000JPEG_TN_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.jpg</upnp:albumArtURI>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="PNG_LRG">http://192.168.50.2:5001/get/213/thumbnail0000PNG_LRG_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.png</upnp:albumArtURI>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="PNG_TN">http://192.168.50.2:5001/get/213/thumbnail0000PNG_TN_Rick.and.Morty.S06E01.1080p.WEBRip.x264-BAE.mkv.png</upnp:albumArtURI>
    <upnp:class>object.item.videoItem.movie</upnp:class>
  </item>
  <item id="224" parentID="212" restricted="1">
    <dc:title>Rick.and.Morty.S06E10.1080p.x265-ELiTE</dc:title>
    <dc:date>2022-12-11T23:15:57</dc:date>
    <upnp:rating>0</upnp:rating>
    <upnp:episodeNumber>10</upnp:episodeNumber>
    <upnp:playbackCount>2</upnp:playbackCount>
    <upnp:lastPlaybackTime>2022-12-12 00:10:04.471</upnp:lastPlaybackTime>
    <upnp:lastPlaybackPosition>0:00:05.000</upnp:lastPlaybackPosition>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" bitrate="209144" colorDepth="8" duration="0:22:00.616" nrAudioChannels="6" protocolInfo="http-get:*:video/x-matroska:DLNA.ORG_OP=01" resolution="1920x1080" sampleFrequency="48000" size="276199388">http://192.168.50.2:5001/get/224/Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_RES_320_180;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="320x180" size="2116">http://192.168.50.2:5001/get/224/thumbnail0000JPEG_RES320x180_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.jpg</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="320x180" size="2116">http://192.168.50.2:5001/get/224/thumbnail0000JPEG_SM_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.jpg</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="160x90">http://192.168.50.2:5001/get/224/thumbnail0000JPEG_TN_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.jpg</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/png:DLNA.ORG_PN=PNG_LRG;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="320x180">http://192.168.50.2:5001/get/224/thumbnail0000PNG_LRG_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.png</res>
    <res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:image/png:DLNA.ORG_PN=PNG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00900000000000000000000000000000" resolution="160x90">http://192.168.50.2:5001/get/224/thumbnail0000PNG_TN_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.png</res>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="JPEG_SM">http://192.168.50.2:5001/get/224/thumbnail0000JPEG_SM_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.jpg</upnp:albumArtURI>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="JPEG_TN">http://192.168.50.2:5001/get/224/thumbnail0000JPEG_TN_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.jpg</upnp:albumArtURI>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="PNG_LRG">http://192.168.50.2:5001/get/224/thumbnail0000PNG_LRG_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.png</upnp:albumArtURI>
    <upnp:albumArtURI xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" dlna:profileID="PNG_TN">http://192.168.50.2:5001/get/224/thumbnail0000PNG_TN_Rick.and.Morty.S06E10.1080p.x265-ELiTE.mkv.png</upnp:albumArtURI>
  </item>
</DIDL-Lite>
Havok1769
Post by Havok1769 »
Well .... shit!!!!
I've confirmed the "Replace file names with library titles" option is turned off in Kodi.
Kodi forums say it's on the UMS side
UMS forums say the logs show it's on the Kodi side
Yeah I would say it is on Kodi's side. UMS is giving all the correct information but Kodi is choosing to use the episode name to display and sort.
I had a quick look on the Kodi website and it's wiki but did not dig too deep. I did see that there is a Sideblade Menu and it has a "sort by" option
Sort by
    Select how the list of Movies/TV Shows/Episodes are sorted: e.g. Title, PlayCount etc
I would assume this would sort by episode number too.
I don't know if Kodi creates logs but would be interesting to see what it is doing if you can post some to compare.
There is the option to turn of UPnp but I don't know what effect this will have on how UMS works. That setting is in General settings > Services > UPnP/DLNA service
