Stuck on 'detecting media renderers'
funkytwig
Post by funkytwig »
I installed UMS but could not work it out so I uninstalled and reinstalled it. Originaly it kind of worked, showed a few videoes, but now it just says 'detecting Medier renderers' on the http://localhost:9001/ page.
Ive tried uninstalling again, rebooting, and installing again, rebooting but get the same thing.
Any ideas?
Ben
Re: Stuck on 'detecting media renderers'
Will need to see logs to find out what is going wrong. See the link in my sig for how to do them.
If you try to re-install then make sure you chose the clean install option to delete the previous settings and database just incase they have been corrupted.
