ERROR A serious error occurred during Universal Media Server initialization
tomtom1126
Post by tomtom1126 »
Dear All,
I found the error today: ERROR A serious error occurred during Universal Media Server initialization: Cannot invoke "com.google.gson.JsonElement.isJsonObject()" because "element" is null
UMS start and the file shared ok, but I am not able to modify the setting by using "Setting Old" function. Web not working "http://localhost:9001/"
Attach is the log file, anything I can do?
I try re-install window and re-install the UMS but no use.
Thanks for the help!
Tom
ums_dbg_2023-02-05-13-17.zip
(164.39 KiB) Downloaded 319 times
Re: ERROR A serious error occurred during Universal Media Server initialization
This is a known problem hat had been fixed for the next release. A temporary fix is to turn off the external network by setting "external_network =false" in the UMS.conf
tomtom1126
Dear Mik_s,
Done, its working but the webpage log-in screen still problem, webpage no action even longed-in (still the input ID and password screen).
below is the log show logged
10:35:21 INFO Finding user: tom
10:35:21 INFO Got user from db: tom
10:35:21 INFO User tom logged
10:35:22 INFO Checking user table have admin
Thanks for your checking again.
Tom
That was another problem that I was trying to figure out when I got hit with the initialization error bug. I was sent a test build with that bug fixed but when I tried to replicate the login problem it was working fine again. Even reinstalling the main version it was working so I don't know what caused it.
I thought that the 2 problems might be linked but now I don't if yours won't login after turning off the external network.
It would be helpful if you posted your logs on this Issue on GitHub. Just make sure it is in trace mode when you do them (see the section in red)
One of the things I was going to test was to delete the users data so I could create a new Admin and see if that fixed it. I was also going to try accessing UMS from another computer on the network to set this up in case it was something about using the http://localhost:9001/ IP address. If you want to try that the user data file is "C:\ProgramData\UMS\database\USERS.mv.db"
Before you do that try clearing cookies and site data for localhost (or UMS's IP if from another computer) and see if that does anything.
tomtom1126
Dear mik_s,
Thanks for your info. I try to delete the users.mv and create the new account but still not working.
Anyway, attach is the log file for your investigation.
Thanks so much!
Tom
ums_dbg_2023-02-05-17-43.zip
(299.03 KiB) Downloaded 369 times
I think the initialization bug was a problem with our metadata API which I have now fixed, and have set up an alerting system so it doesn't happen again. Are the settings working now with 13.2.0?
