13.7.0
13.7.0
General:
Here we have fixed many bugs reported by users and improved security. We are really closing in on v14 with access control now!
Click here to see all changes in this release
Download:
Our previous version is now available on our download page and from our official mirrors.
Support us:
efpom
Re: 13.7.0
Post by efpom »
Most of my mkv videos would not play with trans coded subtitles
Re: 13.7.0
Please make a post in the help and support section and post your logs. Instructions are in the red box at the top of that section.
pipin
Re: 13.7.0
Post by pipin »
Hm, it seems this version is not working for my entire network.
Reverted to 13.6.0 and everything is fine.
Regards,
Jens
icenlord
Re: 13.7.0
Post by icenlord »
I think the reason that happened to you is that this version took all of your whitelisted devices and made them blacklisted.
Maybe one of the mods can explain a workaround that would suit most users in the meantime until the next version is released.
pipin
Re: 13.7.0
Post by pipin »
icenlord wrote: Sat Nov 04, 2023 7:56 am I think the reason that happened to you is that this version took all of your whitelisted devices and made them blacklisted.
No, I noticed that and dropped all whitelisted devices. But it did not work nevertheless.
Regards,
Jens
icenlord
Re: 13.7.0
Post by icenlord »
I also had to go into the web settings, and click the tiny menu with the dots on the top right, under blocked devices and tell it to allow by default
I'm not sure how to explain this properly and I cant seem to be able to post a screenshot.
I struggled with this on the first day 13.7.0 came out as well
I hope you can get it to work for you, best of luck!
Re: 13.7.0
icenlord wrote: Sun Nov 26, 2023 10:38 pm I also had to go into the web settings, and click the tiny menu with the dots on the top right, under blocked devices and tell it to allow by default
that should not be happening with this release unless I made a mistake in the release process. I will check
