VideoLAN version
lastmoexit
VideoLAN version
Post by lastmoexit »
was curious if it is still advisable to use VLC v0.9.8a (as listed in the Help tab) or would the most recent version work? ...not sure if this has anything to do with which version of VLC is used, but none of the TEDTalks under Web seem to work ...a video thumbnail shows for each one, but when trying to play it returns: This content cannot be played. (800288E1) ...is there anyone else experiencing this, as well? ...thank you for all the work/effort/time put into UMS ...it is GREATLY appreciated ...peace
Re: VideoLAN version
Hi lastmoexit :)
A community member has been doing some work on improving VLC support. At the moment it has been neglected for a long time, but if he continues his work we may see good support for the latest VLC
lastmoexit
good to know and thanks for the quick response ...any idea on the TEDTalks problem?
