UMS hangs on saving configuration changes
BitEater
Post by BitEater »
Hi all,
I just installed UMs on my new WIndows 10 computer. Basically it works. I was able to adapt the "Shared Content". But unfortunately I am not able to save configuration changes. If I try I shows "Saving your configuration changes" and hangs without actually saving the changes.
20231103 UMS Saving config.png (5.45 KiB) Viewed 9690 times
Debug files are attached.
Any Ideas what is wrong here?
Thank you
_ums_dbg_2023-11-03-16-43.zip
(339.6 KiB) Downloaded 295 times
Re: UMS hangs on saving configuration changes
This is a known bug and has been fixed in 13.8.0
It is not actually hanging, the notification just does not go away.
You can still use the old GUI if you need to change some settings or edit UMS.conf in a text editor.
BitEater
Post by BitEater »
mik_s wrote: Sun Nov 05, 2023 4:23 pm This is a known bug and has been fixed in 13.8.0
Thank you. I just subscribed to Patreon and downloaded it. Hopefully it works.
Unfortunately not only the notification was hanging, also the configuration was acutally not updated and it seems there are not all options available in the old GUI.
The saving should work on 13.8.0 but I think the notification fix might not be in that version as I was doing some testing with this on the V14 snapshot for something else and reported this issue.
