ALL Files Show As MPEG After Update to 3.4.0 - NOT 3.3.0
AYColumbia
Post by AYColumbia »
I just wanted to report that this issue has come back again in the latest 3.4.0. Was NOT an issue up to 3.3.0.
AYColumbia
Re: ALL Files Show As MPEG After Update to 3.4.0 - NOT 3.3.0
Thanks for creating a new thread as I wasn't sure if I should create one or not. Just a quick history note, this was an issue back in version 2 that was eventually fixed and has not come up until the latest 3.4.0 update. I confirmed it on two servers. My device is an Oppo BDP-103 Blu-ray player.
Here's the original reported thread for v2: [Fixed] ALL Files Show As MPEG After Update to 2.2.x
ExSport
Post by ExSport »
What about to send debug package in TRACE mode? Before asking check forum for what is needed when you make error report 8-)
AYColumbia
I grabbed 3.4.1 and this is still an issue. Any ETA on a fix? Thanks.
Like ExSport said it's hard to fix without logs :)
I've uploaded a version I'd like you to test, and let me know if it has the bug. If it has the bug please provide logs, you can get instructions on how to do that in my signature, thanks :) Download link
I just tested it on my Panasonic TV and couldn't reproduce the problem so definitely need logs for this one
AYColumbia
SubJunk wrote:I just tested it on my Panasonic TV and couldn't reproduce the problem so definitely need logs for this one
I just PMed the link to the log for you. I'll grab the test version shortly and test it. Thanks much.
AYColumbia
SubJunk wrote:Like ExSport said it's hard to fix without logs :)
The only reason I didn't provide the log is I figured you may not need it since it was a known issue that you fixed before and didn't want to inundate you unnecessarily. I figured if you needed a new log, you'd ask. ;)
AYColumbia
The test version does NOT have the bug. Did you still want me to log a bug at the new bug tracker?
Great, thanks a lot for testing it :) I've uploaded two more versions to help narrow it down if you don't mind :) I don't need logs for these unless one has the bug
http://www.spirton.com/uploads/UMS/UMS-63eb40a.exe
http://www.spirton.com/uploads/UMS/UMS-d32cc6b.exe
