UMS does not save settings
Lammerts
Post by Lammerts »
I use a Debian 10.x headles server to run UMS. Besides my other problem thea my yamaha does not play DTS, when i try to save settings ik keep the following message (used Chrome, Safari, IE11)
UMS saving.JPG (12.21 KiB) Viewed 12698 times
When i manual edit the UMS.conf file and go back (after reboot) to the renderer settings, it does not show the selected renderer.
Re: UMS does not save settings
The saving problem was a bug that is now fixed in the latest version.
I think there is no timeout on the notification so it will appear to be saving constantly but I know this has been fixed properly in V14.
What do you mean it won't show the selected renderer? Are you forcing UMS to use a renderer?
Lammerts
Post by Lammerts »
I tried to force a specific renderer (A2050 or A1010) but because it would not save settings it did not work at all
I am in the process of installing new Debian 12.x headless server and do new UMS setup, but can't find V14
When is V14 available? I searched the download files, but latest is still 13.8.0
If you force a renderer then everything on your network will appear as that renderer. Best to leave this disabled and let UMS pick the right conf.
The beta for V14 is publicly available, see the announcements section for the links.
