Subtitle Issue with 1.4.0
Madoka
Post by Madoka »
Yes, it's me again, the subtitle whore.
There is a persistant subtitle problem with 1.4.0 with .ass subtitles with .mp4 files. Also happens with 1.3.0 and PMS 1.60. All the subtitles play fine in 1.2.0 and PMS 1.54.
For the following file, I will lose all formatting and UMS will use the Override Styled Subtitles settings. If there is a lot of text on-screen, like during karaoke, I will get a jumble of text on the bottom.
General
Complete name                  : G:\J-Drama\Carnation\Carnation (Week 14) ep076 (1280x720 x264).mp4
Format                         : MPEG-4
Format profile                 : Base Media
Codec ID                       : isom
File size                      : 236 MiB
Duration                       : 15mn 1s
Overall bit rate mode          : Variable
Overall bit rate               : 2 201 Kbps
Writing application            : Lavf52.64.2
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : [email protected]
Format settings, CABAC         : Yes
Format settings, ReFrames      : 3 frames
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Duration                       : 15mn 1s
Bit rate                       : 2 000 Kbps
Width                          : 1 280 pixels
Height                         : 720 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 29.970 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.072
Stream size                    : 222 MiB (94%)
Writing library                : x264 core 104 r1713 c276662
Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=0 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=150 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2000 / ratetol=4.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format                         : AAC
Format/Info                    : Advanced Audio Codec
Format profile                 : LC
Codec ID                       : 40
Duration                       : 15mn 1s
Bit rate mode                  : Variable
Bit rate                       : 127 Kbps
Channel(s)                     : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 48.0 KHz
Compression mode               : Lossy
Delay relative to video        : -100ms
Stream size                    : 13.7 MiB (6%)
Carnation Debug.txt
(25.56 KiB) Downloaded 496 times
For this file, the font is correct , but the size is huge. Text that used to be one line on the bottom with be several lines long, taking up 50% of the screen. Sometimes, the whole screen will be a wall of text.
General
Complete name                  : G:\J-Drama\Magma\Magma.ep01.480p.x264-[D-Addicts].mp4
Format                         : MPEG-4
Codec ID                       : isom
File size                      : 280 MiB
Duration                       : 54mn 0s
Overall bit rate               : 724 Kbps
Encoded date                   : UTC 2012-06-11 10:15:29
Tagged date                    : UTC 2012-06-11 10:15:29
Video
Format                         : AVC
Format settings, ReFrames      : 4 frames
Codec ID                       : avc1
Duration                       : 54mn 0s
Bit rate                       : 592 Kbps
Maximum bit rate               : 4 198 Kbps
Width                          : 848 pixels
Height                         : 480 pixels
Color space                    : YUV
Bit depth                      : 8 bits
Bits/(Pixel*Frame)             : 0.049
Stream size                    : 229 MiB (82%)
Writing library                : x264 core 120 r2164 da19765
Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=21.5 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date                    : UTC 2012-06-11 10:15:52
Audio
Format                         : AAC
Format profile                 : LC
Codec ID                       : 40
Duration                       : 54mn 0s
Bit rate                       : 128 Kbps
Maximum bit rate               : 138 Kbps
Sampling rate                  : 44.1 KHz
Stream size                    : 49.4 MiB (18%)
Encoded date                   : UTC 2012-06-11 10:15:51
Magma Debug.txt
(55.56 KiB) Downloaded 520 times
Both problems happen on multiple different files, not all form the same source.
Not all is bad. My prior request, that .srt subtitles use the Override Styled Subtitles setting, has been granted. :D
