Improve application icon
Locked
Almondega
Post by Almondega »
Hi, I would like to suggest the improvement of the UMS icon.
I'm not an icon artist to provide a better one, this is just a suggestion ;)
The attached image shows the difference between modern icons and the low quality used in USM application.
Top application requires top icons 8-)
Best regards.
Fiddl3
Re: Improve application icon
Post by Fiddl3 »
try this https://dl.dropboxusercontent.com/u/25208735/icon.ico
if it'll look ok maybe someone from dev team will replace oldone with new
Almondega
Post by Almondega »
Fiddl3 wrote:try this https://dl.dropboxusercontent.com/u/25208735/icon.ico
Hi Fiddl3, thanks for the icon, this is a much better one =)
I'm using it now by manually setting the application icon.
Let's hope the dev team start using this new icon.
Cya.
DeFlanko
Contact:
Post by DeFlanko »
Locked
